BIKELAND > FORUMS > ZX-14.com > Thread: MTC drop-in Pistons are junk NEW TOPIC NEW POLL POST REPLY
1badzx12r
posted March 10, 2010 04:21 PM        Edited By: 1badzx12r on 11 Mar 2010 00:23
i purchased a set ran 10 passes @7lbs of boost .. motor started smoking like van Ryan's express .. pulled the pistons .. rings were stuck... yes ring('S) LIKE ALL OF THEM .. Called MTC .. Sent pistons to MTC ..got a call today .. MTC said the pistons warped and distorted and it was my fault for putting NOZ flat top pistons in a 7lb boost turbo motor .. i told him for 2 years i ran stock piston with up to 14lbs of boost .. Cliff then told me stock pistons have a better top ring land ..and that's why the stockers lasted ..Well if them MTC pistons can't with stand 270hp ..then whats going to happen when somebody sprays a 140 shot of NOZ .. oh and don't let me forget when i was ordering my pistons for a turbo bike ..MTC recommended these pistons along with the 2mm shorter turbo pistons .. and when i got the pistons they sent the wrong wrist pins ..
my dealing with MTC is over never again..
1badzx12r
posted March 10, 2010 05:10 PM
but my pit posse valve spring tool is the best 49.95 i've ever spent period bar none
posted March 10, 2010 05:19 PM
wow... thats bad news.
so you weren't using their turbo piston?
10.5:1 dished for -2mm rods?
same ones Mr Turbo developed?
posted March 10, 2010 05:24 PM        Edited By: smokinZX14 on 11 Mar 2010 01:24
I think he was running a drop in domed piston ? I may be wrong but when i talked to him on the phone he said 12.5.1 piston ? I may have just heard him wrong ..
1badzx12r
no i wasn't dub . i wasn't going to purchase rods to get the same results .. turbo over fukk a turbo ..
1badzx12r
posted March 10, 2010 05:26 PM
there called drop-in 12.5 1 flat tops NOZ pistons .. and they have more deck height than the 10.5 1 turbo pistons .. from what i was told by MTC
posted March 10, 2010 05:27 PM
I guess my hearing is ok ..
1badzx12r
posted March 10, 2010 05:30 PM        Edited By: 1badzx12r on 11 Mar 2010 01:31
Robert,
Attached are the pictures you requested.
The tall deck pistons need the 2mm (0.080”) shorter rods and they are actually only 0.065” taller and then they are 0.015” in the hole to get the lower compression.
The “Drop In” piston is designed for nitrous application because the top ring land has been moved down compared to the stock pistons.
If you have any questions, please let us know.
Thank you,
Eric Hochstetler
MTC Engineering LLC
428 Shearer Blvd
Cocoa, FL 32922
321-636-9480
this was my email .. the rest of the time i talked over the phone
posted March 10, 2010 05:34 PM        Edited By: Shane661 on 11 Mar 2010 01:34
Something doesn't make sense here. How is a nitrous piston with more meat above the ring land going to be more fragile than stock? At the same time, what was your final compression ratio? Why did you go with high compression in a turbo application??
1badzx12r
posted March 10, 2010 05:38 PM        Edited By: 1badzx12r on 11 Mar 2010 01:40
you ever try launching low compression turbo bike and use it for ET racing .. thats why i went with high if you want to call 12.5 1 when stock is 12.0 1 .. i wanted to replace the stock piston with what i taught was a better piston ... but it didn't work and i think in most part because of no r&d by MTC ..
AND I WANTED TO RUN LOW BOOST
posted March 10, 2010 05:43 PM        Edited By: Shane661 on 11 Mar 2010 01:44
12.5:1 sure seems high to me, but maybe I'm just conservative like that. Maybe have a custom set made by CP?
1badzx12r
posted March 10, 2010 06:00 PM
NO ..i'm done shane . back to stock .. sell the bike and get a turbo busa off PB or ebay ..
posted March 10, 2010 06:58 PM
Well, I said before Robert, you are a very tenacious person. I would have gave in to a big bore stroker a long time ago.
I will not be fucking with mine as much as you did yours, I don't have the time , money or patience.
wish me luck?
PS I posted my piston findings, I think you will find no matter what the build, there is allot to consider when looking at pistons, and much much more to measure...
1badzx12r
posted March 10, 2010 07:15 PM
wish me luck?
i do wish you luck ..ps if you don't use boost or hot rod it last forever ..
posted March 10, 2010 07:18 PM        Edited By: dubious on 11 Mar 2010 03:33
I intend to run the shit out of it, once its tuned, progressively turning it up.
Gotta get it good, before we can get it fast!
06redzx14
posted March 10, 2010 07:22 PM        Edited By: 06redzx14 on 11 Mar 2010 03:23
1bad is your old motor still fixable(no hole in cases and can be used for big bore)? I'm hunting for a big motor donor. pm or email me
osti33
posted March 10, 2010 07:26 PM
What kind of fuel were you running? Any timing pulled out?
1badzx12r
posted March 11, 2010 02:18 PM
c109 .. stock timing .. 7lbs of boost ..
1badzx12r
posted March 16, 2010 11:10 AM        Edited By: 1badzx12r on 16 Mar 2010 19:11
got my warped and distorted pistons back today from MTC ..big time junk .. the piston wall between #2 ring and oil ring is to thin and warps .. and from what MTC told me colby adams buys these pistons by the truckload and makes them work .. on NA bikes with noz that is .. i'm installing the shitty stocker back in it ..
posted March 16, 2010 04:00 PM
Can you mail one to me? I will pay you for it!
I want to make sure mine are of different design above the pins.
posted March 16, 2010 04:02 PM
can you post pics? side profile and inside the domes/ walls like I did?
Now you got me scared, damnit Robert! LOL
1badzx12r
posted March 16, 2010 05:47 PM
i'm telling you from your pics you posted ..only differance is the 1 mm of space between the rings on your piston vs my drop-in junk
1badzx12r
posted March 17, 2010 05:08 AM
and their still junk today
posted March 17, 2010 01:37 PM
So let me get this straight, Coby Adams can get these to live with big shots of nitrous... but they are junk because you blew your shit up?
1badzx12r
posted March 17, 2010 03:31 PM
fuck you kz scott and colby adams too .. . i haven't ever even seen a colby adams bike run anything in this area ... let me guess you heard over the internet how great of a bike he builds ...but you go right ahead and buy you a set .. i didn't blow nothing up .,.can't you read ..they warped and distorted as MTC told me ... because i put noz piston in a turbo with 7lbs of boost running in 50 degree temps and runnning c109 a total of 8 passes ..
AND YES THEY ARE STILL FUCKING JUNK
0.5531759262085 seconds processing time
