BIKELAND > FORUMS > ZX-14.com > Thread: Injector Question '06 vs. later models?? NEW TOPIC NEW POLL POST REPLY
Ozonkiller
posted March 09, 2010 06:34 PM
I have a spare set of throttle bodies that I'm not sure what year they are. I'm messin' with E85 and think that I may want to go to the later year ('08 & up) injectors as I understand that they flow more.
Is there a way to look at the injectors and tell if they are the '06-'07 or the later ones?
Am I correct in understanding that the later ones have more holes.
Sorry, I tried the search do-dad with no luck.
Thanks in advance
Tom
posted March 09, 2010 06:50 PM
yes 10 holes for 06-07 and 12 holes 08 up I think... 98% sure
better way to tell diff is the 06-07 are blue and numbers on side are:
EAT286 for 06-07- blue
EAT 287 for 08 up - green in color.
If you look at them on the bike from clutch side you will see number
Ozonkiller
posted March 09, 2010 06:51 PM
Awesome!! That's what I needed to know.
Thanks,
Tom
Ozonkiller
posted March 09, 2010 06:58 PM
OK, so I just went out to the shop and counted the holes. Must be '06-'07.
I should be able to accomplish the same thing if I jack up the fuel pressure.
I know some of you who are spraying or are turbo'd have jacked up the fuel pressure by shimming the relief.
Has anybody suffered reliability problems with the pumps after doing this?
Tom
oldkawboy
posted March 09, 2010 07:57 PM
I remember something about the angle of the injector or spray pattern being different on the second generation too, maybe it's got to do with the increased number of holes.
Do the '08 & up injectors fit the older bodies?
Just wondering if the newer injectors will help or are the throttle bodies different too?
Thanks,
Dan
Compton
posted March 09, 2010 08:01 PM
yes the 08-09s fit in the older throttle bodies, i have em in mine
b.w.
68gts2
hobbies ( Beating you !!! )
posted March 10, 2010 09:46 AM
Compton,did they help your bike any?
oldkawboy
posted March 10, 2010 04:18 PM
Thanks Compton for the answer, I was just curious.
Dan
BIKELAND > FORUMS > ZX-14.com > Thread: Injector Question \'06 vs. later models?? NEW TOPIC NEW POLL POST REPLY
0.2497980594635 seconds processing time
