BIKELAND > FORUMS > ZX-14.com > Thread: PCV quick shifter project NEW TOPIC NEW POLL POST REPLY
zx14r09se
posted March 07, 2010 04:29 AM
ok here it is...I want to do my quick shifter but i need info an power commander dont have any or i didint look a the rigth place or ther wanna sale there sensor anyway here is my project
one switch to cancel the horn and make it so when i push it it dose just like the quick shifter sensor(i just have to load the shifter pedal with my foot and then push the horn button and voila)
or flic the switch again and now its the shift ligth that will triger a relay and voila it shift at given rpm( with me loading the shifter pedal again) if i want my horn back put the switch back to original position
now the question is::::::
what is the signal that the quickshiter sensor from dynojet gives the PCV and were do i plug it
for the switch and shift ligth and realy im good its just that i dont whant to burn my pcv
there is 2 pins on the pcv that say shiter is it a ground singal or oms or voltage and if so what is it
What do you think of my idea is it good or im ganna break somthing
thanks
live to ride...but only on a 14
  Ignore this member    Click here to visit zx14r09se's homepage.
0.21196889877319 seconds processing time
