BIKELAND > FORUMS > ZX-14.com > Thread: Rods & pistons NEW TOPIC NEW POLL POST REPLY
johnbull
posted March 02, 2010 10:44 AM
Rods & pistons
What is the best setup to go for regarding rods and pistons for a boosted application??
Standard length Carrilo rods and 9.5 low compression JE pistons?? Or would you guys suggest a shorter rod than OE??
Looking forward to opinions.
John Bul Racing. Malta.
CraigChrist
BAWLS
posted March 02, 2010 05:25 PM
I believe dubious was talking about his setup in the stroker thread.
60ft-------1.42
1/8th------5.97
mph-------119
1badzx12r
posted March 02, 2010 05:41 PM
STOCK RODS AND MTC drop-in FLAT TOP pistons here
posted March 02, 2010 09:18 PM
The pro's are all running -2mm rods, carillo or falicon, and turbo pistons with +2mm taller compression height (+2mm deck above top ring)
JE makes a nice piston as does CP, both using stock rings.
MTC also makes stout piston for turbo application and -2mm rods and uses BIG rings, and massive oil scavenging abilities.
Either way, pistons can take more beating on the exhaust valve releif before blowing the top ring land away.
Its added insurance for boost, but not necessary below 10 lbs boost with the right tune, fuel and timing.
Are you addicted and looking to turn it up?
or did the pistons pop already?
01smokes
posted March 02, 2010 09:31 PM
Im gonna be looking into getting some soon as well, i have the cash now to pick them up now but not quite enough to get them put in the bike so ill be keeping a eye out on what to get
PayPal, vigilart22@yahoo.com
Email, artvgl@yahoo.com
johnbull
posted March 03, 2010 12:19 AM
Haha, nop not yet....I'm just thinking of what rods and pistons to go for in the near future to make the engine more reliable.
Re. the -2mm shorter rod which you mentioned, is this a good idea?? Wouldnt a shorter rod increase the angle's that the rod would go through every revolution??
Or is it a case of sacrifiesing rod length in order to increase ring land?
Cheers.
1badzx12r
posted March 03, 2010 04:06 AM
i've never seen a piston on a zx14 melt at the exhaust valve .. alway been the intake valve side .. and from what i learned on my bike ..it don't really matter on what kind of piston you have .. but at least when the J&E turbo pistons melted it didn't take out the case's .. testing ceramic coating also this time..
but i just wish the guys thats all fried piston or busted rods with turbo zx14's would just share info.. but instead its a big fukkin secret ..
wndsrfr
posted March 03, 2010 05:35 AM
i'm havin good luck with falicon rods,
j&e ceramic/teflon 9.5 pistons
01smokes
posted March 03, 2010 06:49 AM
Thats the biggest thing i hate about bike guys everything is a fuckin mystery, ya there are a few out there that share info but but if everyone would just speak up we all would be going ALOT faster
posted March 03, 2010 06:55 AM
That is precisely why the fast guys keep things secret.
NINJA12
posted March 03, 2010 03:43 PM
There's a lot more busa information floating around than any zx1* .
If it were not for the help from a very select few this site would be 100% entertainment and 0 % helpful.
There is no teamwork on the kawasaki side. It took Brock (a suzuki guy) to bring us a decent pipe with a map that didn't REQUIRE dyno session to get close, and customer service that would help you with the same courtesy they took your order.
We have people come here to advertise their magic feats with stock engines, but not a single bit of information.
posted March 03, 2010 03:46 PM        Edited By: Shane661 on 3 Mar 2010 23:46
Well, I've given about all of the data that I can. But I'm a slow guy.
1badzx12r
posted March 03, 2010 04:05 PM
shane .i'm not asking for the secret tuning ..just like to know what happen to a motor when it craps out .. can't see where that would be taking info from the fast guys .. fast guys shitt blows up too.. and all they have to say is what gave up on the piston ..where it melted or which rod busted
1badzx12r
posted March 03, 2010 04:06 PM        Edited By: 1badzx12r on 4 Mar 2010 00:35
but instead you see turbo's for sale but no info why its for sale .. or a noz bike with a new motor for sale .. but what happen to the old motor
posted March 03, 2010 04:12 PM
See...but keeping the motor alive is the key to going fast and getting the points. Hence, the secrets.
1badzx12r
posted March 03, 2010 04:36 PM        Edited By: 1badzx12r on 4 Mar 2010 00:36
let me know when you found some that been keep alive and gone fast ..
cause fast and alive don't mix
posted March 04, 2010 05:41 AM
John, the rod to stroke ratio is well above 1.8:1 still, so angles are still very safe, and the turbo pistons have longer skirts, to alleviate the skirt / wall scuffing from the very slight angle change.
Usually gusy who change the rod length are running stroker cranks for the displacement, so the change is doubled compared to just the rod for out purposes.
Most gusy running GSXR and ZX10 monoblocks are also doing the same, -2mm rod, stock crank.
The busa guys don't have to -2mm rod since they can put a spacer under the cylindersand the stock piston design
0.21761512756348 seconds processing time
