BIKELAND > FORUMS > ZX-14.com > Thread: ecu guys explain this NEW TOPIC NEW POLL POST REPLY
1badzx12r
posted February 16, 2010 05:42 AM
i installed a freinds ecu from his bike . ok his ecu has always threw a code 23 . well guess what my bike now does it ..and has never threw a code 23 ..
kawasakijockey
posted February 16, 2010 05:52 AM
That is a cam sensor failure or wiring short or open circuit code. Some of the codes are not erased from the ecu history even when the problem is corrected.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
1badzx12r
posted February 16, 2010 04:41 PM
thats what i figure .. but why does it throw a code only with that ecu .. when i got my old ecu it throws no code and cam postition sensor works perfect .. in fact today when riding its flooding with fuel in cruising rpm's ..and on my old ecu its runs perfect at the same rpms
Obba
posted February 17, 2010 12:06 AM
As kawajockey says:
14nooby
posted February 17, 2010 04:48 AM
I wonder if the dealer has a scan tool to clear the codes?
1badzx12r
posted February 17, 2010 05:32 AM
wouldn't that be great .. but i doubt it .. but i'll call and ask
posted February 17, 2010 05:46 AM
maybe ridgeracer could flash it for you.
We need to get him started on a MAP / boost based ecu set up for the turbo's too...
it would be great if you get a head start on this Rob.
INTIMIDA2OR
RED rider!
posted February 17, 2010 10:35 AM
I believe the FSM tells how to get rid of the code. But that wouldn't cure the problem I don't think.
The problem is definitely the ECU. Don't know if it can be fixed but...
'06 Passion Red ZX-14
*Lee*
1badzx12r
posted February 17, 2010 03:58 PM
I believe the FSM tells how to get rid of the code..
no it doesn't ..all it states is that codes are stored as memory for the bike service records
INTIMIDA2OR
RED rider!
posted February 17, 2010 11:15 PM
Geez that must be a female ecu!
*Lee*
0.22055292129517 seconds processing time
