BIKELAND > FORUMS > ZX-14.com > Thread: Ground cable on PC3 NEW TOPIC NEW POLL POST REPLY
blackmamba
posted February 14, 2010 01:10 PM
Ground cable on PC3
Where are you guys bolting the ground cable that comes off the harness on the PC3. Instructions don't mention where to bolt that down to.
Thanks,
Abe
www.packleader.org
kawasakijockey
posted February 14, 2010 01:12 PM
Run it to the battery ground.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
Compton
posted February 14, 2010 01:26 PM
i made up a 12 gauge wire from the ground on the battery to the over flow. cut the over flow so its only being held up by two bolts and used the third as a dedicated ground for it.
b.w.
gilberjj
Friend of Fast
posted February 14, 2010 02:15 PM
I mounted my pcIII under the seat, and pulled the engine harness across to the clutch side. In doing that, I was able to connect the ground to the negative terminal on the battery. That's the best way to do it imo. It's a PITA but it's the best way.
posted February 14, 2010 02:21 PM
+1
it's not easy getting it ran unde the seat but well worth every min. If you ever want to change maps it's as easy as taking your seat off!
Compton
posted February 14, 2010 03:12 PM
Or run it up front and just run a usb cable to the back. Makes maps easy too
b.w.
Quarter Pounder
with Cheese
posted February 15, 2010 02:45 PM
yep, I had mine in the front left cowling, but recently moved it under the seat. Much better access.
SWB 2008 ZX-14
9.19 @ 151
5.98 @ 123
1.53 60'
posted February 15, 2010 03:35 PM
if you like pain, mount it to the water bottle bolt per the directions that came with mine in '06
Newf14
2007 ZX1400
posted February 15, 2010 04:19 PM
I have the ground under the coolant bottle than I spliced in a wire and ran it accross to the negative post on the frame. I also pur my PC3 and speedo healer under my seat as well worth the trouble.
Newf14
0.2107138633728 seconds processing time
