BIKELAND > FORUMS > ZX-14.com > Thread: Got my PC3 in the mail today.... NEW TOPIC NEW POLL POST REPLY
blackmamba
posted February 09, 2010 06:13 PM
So please guide me. Looks like a plug and play but are there any threads on where the best place to mount is? What will I need?
Also what is the best thread for removing the fly's...plan on doing this in my garage the next few days.
After this monster storm we had here in the suburbs of chicago it will be even more depressing to install!
Abe
www.packleader.org
CraigChrist
BAWLS
posted February 09, 2010 06:51 PM
Here's a link for the power commander...
http://brocksperformance.com/Instructions/ZX14/ZX%20-%2014%20POWERCOMMANDER.pdf
I can't find a good flies post since the search feature sucks so bad these days
60ft-------1.42
1/8th------5.97
mph-------119
Ozonkiller
posted February 09, 2010 06:57 PM
For the flies, buy a brand new quality screw driver. Don't use a worn out one or a POS Chinese, Harbor Freight one. I've had good luck with Klein.
blackmamba
posted February 09, 2010 07:06 PM
where can you buy a klein screwdriver? philips or flat?
www.packleader.org
posted February 09, 2010 07:07 PM
i hear this works well:
heat the screwdriver with a torch, stick it in the screw head and hold it there to transfer the heat to the screw to melt the factory thread locker to avoid stripping the screw head.
LOCK 2121
posted February 09, 2010 07:28 PM
LOWE'S , HOME DEPO , PLATT ELECTRIC,
Douglas Home
posted February 09, 2010 07:33 PM
Most problems with PC are bad neutral , I ran one direct to the the battery ground lead bolt on the right hand side by the battery cover.
Doug Mackay Australia
blackmamba
posted February 09, 2010 07:49 PM
Stupid question...
Does the PC need to be plugged into the bike in order to load maps and for computer to recognize it is connected?
I just installed the program on my computer and it's not recognizing the PC through the USB port.
I was hoping to load my map now and it be read to toss right on....
www.packleader.org
dakota9498
posted February 09, 2010 07:53 PM
As long as you have the USB connected and the little adapter to hook up 9v battery it should be reading it.
2008 ZX14
CraigChrist
BAWLS
posted February 09, 2010 08:21 PM
If not, load it while it's hooked up to the bike and the bike's running. If you need the 9v adapter, you're more than welcome to mine. I always just hook my laptop up while the bike is running. Shoot me an email if you need it. Chadley.yates@gmail.com
60ft-------1.42
1/8th------5.97
mph-------119
CraigChrist
BAWLS
posted February 09, 2010 08:43 PM
Finally found the thread from back in the day where I was pulling mine. There are some links in it.
http://www.bikeland.org/board/viewthread.php?FID=27&TID=41103&set_time=
60ft-------1.42
1/8th------5.97
mph-------119
blackmamba
posted February 10, 2010 08:18 AM
Thanks for the offer. I was wondering what the other connection was on the PC. I'll just wait to have it my bike running and the PC connected.
What about the groud wire coming off the two harness connectors? Where are you guys grounding that?
www.packleader.org
0.3179669380188 seconds processing time
