BIKELAND > FORUMS > ZX-14.com > Thread: Purchased the PC3 and got a few questions... NEW TOPIC NEW POLL POST REPLY
blackmamba
posted February 02, 2010 05:40 PM
I won't be riding the bike for another 30-60 days most likely due to shitty illinois weather. Should I wait to pull the fly's and install the PC or should i do this without riding the bike first?
The bike has front and rear sprocket, with a stock exhaust. Is there a map for pulled fly's and stock exhaust? Is there a map for sprockets? I would assume no map for the sprockets...
What should i do boys? Be proactive or wait so I can actually feel the difference.
How bad is the install of the PC by the way?
Thanks,
Abe
www.packleader.org
jarhead
posted February 02, 2010 05:58 PM
If you just purchased the bike and have not had a big bore bike before I would suggest that you wait. If you have had other big bores then I would go ahead a pull the flies and install the PC. As far as what maps are out there I do not know. If you are going to stay with the stock pipes it may be a bit harder to find a good map. BTW, I am with you on the winter thing, I am in NE Indiana so after mother nature finishes dumping snow on you guys she heads my way.
SixSixoh6
posted February 02, 2010 06:33 PM
Thanks,
Abe
1. pull flies and install pc3, its not hard to install at all.
2. sprockets dont make a difference on fueling. so the answer is no.
3. might as well get used to the bike with the flies removed cause you will remove them anyways.
also i believe there is a map with stock exhaust, stock filter and flies pulled. may wanna double check dynojet.com
SixSixoh6
posted February 02, 2010 06:34 PM
just found this...off the site
M224-011 Stock exhaust, Stock air filter, Secondary butterflies removed
thats direct from dynojet.com
blackmamba
posted February 02, 2010 06:39 PM
will a k&n filter make a difference on that tune sixsixoh6?
www.packleader.org
dcjens
Wet side of Washington
posted February 02, 2010 06:54 PM
twist the thing on the right handlebar..that will make the difference...how far you wanna be in front?
Black 06
SixSixoh6
posted February 02, 2010 06:59 PM
nah, they usually say on them "stock or aftermarket filter"
SixSixoh6
posted February 02, 2010 07:00 PM
that too!! just be sure to hang on haha
INTIMIDA2OR
RED rider!
posted February 02, 2010 09:32 PM
Definitely pull the flies! Free power!
'06 Passion Red ZX-14
*Lee*
posted February 03, 2010 04:50 AM
Thanks,
Abe
1. Remove the flies while the weather is bad. No need in tearing the bike down during good ridin weather.
2. Install the pc. You can either install it where the directions show or you can put it under your seat. A lot easier to access under the seat.
3.A/f ratio has nothing to do with gears.
4. Get all this stuff done so you can ride as soon as the weather allows!!!
What size sprockets are on the bike now? 17/41 is stock.
0.25191617012024 seconds processing time
