BIKELAND > FORUMS > ZX-14.com > Thread: How do I get the spring off the shock? NEW TOPIC NEW POLL POST REPLY
posted January 30, 2010 11:19 AM
I have already taken the shock out of the bike. I will be home in about 3 hours and Im jumping on this myself. I can get the spring compressed, but I wanted to talk to someone that has done this before. Just making sure before I run into something that gets me stuck.. Thanks for any info on this subject!
posted January 30, 2010 02:18 PM
Ok that went a lot easierthan planned. Very simple. I used 8 hose clamps and it was not a lot of pressure on any of them. The only problem I ran into is the spring came with a metal sleeve that sits on the bottom of the spring. If you use the sleeve, you can't use the plastic cover that is protects the shock shaft from gettig dirt on it..
kawasakijockey
posted January 30, 2010 02:25 PM
I didnt use any sleeve with my busa spring, just the plastic one that comes on the 14 shock.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
posted January 30, 2010 02:27 PM
you know how that plastic thing is shaped at the base, where it goes under the spring? This flange is the same shape at that, just metal. With my driveway being almost 1/2 mile dirt I think I need that cover protecting the shock... Wouldn't you think?
kawasakijockey
posted January 30, 2010 02:35 PM
That is why I used the stock plastic one.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
posted January 30, 2010 02:38 PM        Edited By: eklipse636 on 30 Jan 2010 22:46
Edit
kawasakijockey
posted January 30, 2010 02:39 PM
Ok
2007 ZX-14
1.38 60ft
9.03 @ 149mph
posted January 30, 2010 03:26 PM
Thanks kawijocky for the quick response!
Got the shock mounted back in place and it might just be me, but I can't tell a lot of difference. I didn't lower it anymore, but with the stock shock the tire was hitting the undertail pretty good.
kawasakijockey
posted January 30, 2010 04:12 PM
If you put an 08-09 busa spring on, you will definately be able to tell. Are you sure it is the newer busa spring?
2007 ZX-14
1.38 60ft
9.03 @ 149mph
Bawls
re-learning to ride
posted January 30, 2010 04:21 PM
It's an Eibach 13.8kg/in from Racetech. I could tell a huge difference on my bike, but he's a little longer and heavier than me.
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
Brockland Police Badge # 001
14nooby
posted January 30, 2010 04:48 PM
Pervert
Bawls
re-learning to ride
posted January 30, 2010 05:35 PM
lol... Touche' salesman... Touche'
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
posted January 30, 2010 06:09 PM
Lol!!
osr
posted February 18, 2010 12:25 PM
I will have my 06-07 zx10 wheels in this week. We are going to try and build a kit to do this swap -- as soon as the wheels are here we will start in on them.
Just weighed the 14 wheels --
Front with rotors (no spacers) 17.4 lbs
Rear with rotor/ sprocket carrier (no sprocket or spacer) 22 lbs
i will post same measurements with the 10 wheels
0.28960800170898 seconds processing time
