BIKELAND > FORUMS > ZX-14.com > Thread: busa spring NEW TOPIC NEW POLL POST REPLY
instag8tr
posted January 24, 2010 04:19 PM
busa spring
What is the best combo for the rear? Busa spring and 14 shock or all busa?
Newf14
2007 ZX1400
posted January 24, 2010 04:28 PM
Busa shock wont fit......Busa spring on the 14 shock is what is used. There is another thred on this topic if you search.
instag8tr
posted January 24, 2010 05:52 PM
search yea right lol
JDC
posted January 24, 2010 06:22 PM
and the reason for using a Busa spring is it is stiffer?
posted January 24, 2010 06:46 PM
They say it's helps a lot. I hope to find out this weekend! Revalvong and a stiffer spring is the best bang for your buck.
Newf14
2007 ZX1400
Yes it is stiffer and helps stop bottoming out when dragracing for bigger fellows on extended swingarms.
P.S top left hand corner is a search box.....
Newf14
1badvespa1400cc
power junkie
posted January 25, 2010 08:42 AM        Edited By: 1badvespa1400cc on 25 Jan 2010 16:42
i'm selling one 100 buck's.include's the 14 shock and the spring together just drop it in and go!!!!
Just another foeteen!!!!!
posted January 25, 2010 08:54 AM        Edited By: Shane661 on 25 Jan 2010 16:55
Adding a stiffer spring to a shock with an already limited damping ability is not ideal. Do some investigation into how a drag racing shock differs from a standard or road racing shock.
For best results, you would definitely want to revalve the shock.
Bawls
re-learning to ride
posted January 25, 2010 09:26 AM
And for the cheapest option put just a spring
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
Brockland Police Badge # 001
madnessracing
Vmax and Busa Beater
posted January 25, 2010 09:47 AM
The 14 shock with the busa spring is good only if you are 200Lbs or more but if you're lighter you will have wheelie problems!
Shorty's Performance
Team Madness Racing
posted January 25, 2010 09:56 AM
I'm wandering how much lower I can go with a new spring? Maybe 1" or 1 1/2"?
posted January 25, 2010 10:08 AM
That's an excellent way to achieve even less rebound control!
Bawls
re-learning to ride
posted January 25, 2010 11:11 AM
I'll take less rebound control over bottoming my bike out on the fuel pump. Judging from the videos of my bike, my stock shock with racetech 13.8 is doing it's job pretty well. Obviously a penske or ohlins or having my stock shock revalved would be ideal, but for the amount of money that I had to spend it wasn't in the cards for me. The way that I see it, if I can ride it fast the way it is, when I get the parts that I "need" it'll be that much easier. I'm also one of those guys that believes in changing one thing at a time and getting the most out of it before changing something else.
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
posted January 25, 2010 11:45 AM        Edited By: Shane661 on 25 Jan 2010 20:34
Well, there are certainly a lot of ways to skin a cat. Smokin goes 8.60's with a bone stock shock, right?
When I rebuilt the bike last winter, I put in a used 08 style fuel pump to gain extra clearance without limiting the suspension travel. Perhaps you have your bike slammed more than mine out back?
Just to give an idea, on a real drag shock the rear suspension may still be lifting at the 1000' mark or beyond. As you know, increasing preload without more rebound will make the shock more likely to pogo up and down. But, bottom line, the most important thing is that it works for you!
How much is the racetech spring, new?
posted January 25, 2010 12:37 PM
Hopefully I getto try out one of these springs next weekend!
0.27227401733398 seconds processing time
