BIKELAND > FORUMS > ZX-14.com > Thread: Sprocket removal NEW TOPIC NEW POLL POST REPLY
zx14fan
posted January 15, 2010 12:09 AM
Sprocket removal
Can the side case over the front drive sprocket be removed in one piece or does the clutch slave have to come off? Thanks
Douglas Home
posted January 15, 2010 02:06 AM
comes off with it. dont squeeze the clutch lever with it off.
dont forget to flatten out the countershaft spline washer before tackling that stuborn countershaft nut with a six point socket!
Goodluck
Doug Mackay Australia
posted January 15, 2010 02:24 AM
One of the bolts that holds the slave on holds the cover on as well. I can't remember which one. Someone will chime in.
I stuck a2x4 in the back tire and let it rest on the swingarm to hold it while you turn the sprocket
BobC
posted January 15, 2010 02:41 AM
It's the longer one on the clutch slave cylinder which goes right through to the crankcase, the other two can stay put.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
posted January 15, 2010 06:20 AM
i know it the longest one, but is it the bottom one or the left? It should be one of those two
gilberjj
Friend of Fast
posted January 15, 2010 10:00 AM
I had somebody hold the rear brake while I took the sprocket off. Don't just put it in gear, I've heard that can be bad on the transmission.
0.28053402900696 seconds processing time
