BIKELAND > FORUMS > ZX-14.com > Thread: Which oil in shock? NEW TOPIC NEW POLL POST REPLY
kawasakijockey
posted January 03, 2010 03:13 PM
Which oil in shock?
I dont mean forks, I mean rear shock. Does anyone know? 5w? 10W?
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
posted January 03, 2010 03:44 PM
contact this guy? scott@zx14racing.com
He posted he revalved and put heavier oil in his rear shock for $350 instead of spending a fortune on an aftermarket drag shock
posted January 03, 2010 03:58 PM
remember, if you use heavier oil it takes longer to get to proper operation !!!
Long rides heavy oil...
Short rides light oil...
posted January 03, 2010 04:01 PM
CR, won't the revalve change those properties?
kawasakijockey
posted January 03, 2010 04:28 PM
The rides are going to be very short. Like a quarter mile...
2007 ZX-14
1.38 60ft
9.03 @ 149mph
14nooby
posted January 03, 2010 04:54 PM
I looked into doing it myself but the tools through RaceTech cost more than sending the shock out to someone. Post us your results please.
kawasakijockey
posted January 03, 2010 05:08 PM
The only thing I will need that I cant do is needle charge the nitrogen reservoir. I have a busa shock that I did some surgery on today. It isnt complicated.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
posted January 03, 2010 05:15 PM
Of course but the oil still needs to warm up then the shock will be working at its best...
works the same as different engine oil weights.....
You just need to decide which is best for your need...
NINJA12
posted January 03, 2010 05:20 PM
Race shock better work best cold
, unless you plan to bounce on it in the pits.
kawasakijockey
posted January 03, 2010 05:25 PM
I got the idea of just changing oil weights from a guy who did it to his shock. It really slows the shock up with the heavier oil on his bike.
NOTICE: DONT TRY OPENING THE SHOCK IF YOU HAVE NO IDEA WHAT TO DO. There is a nitrogen bladder in there with 150psi in it.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
LAB3
I have a stock 08 Busa shock too??? What did you do to get it to mount on ZX-14?
kawasakijockey
posted January 03, 2010 05:30 PM
I meant I used it to experiment with. I wont pull the 14's until I find a nitrogen recharger in town.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
kawasakijockey
posted January 08, 2010 07:36 PM
I had a local suspension guy revalve the shock to slow the rebound. The shocks have a 3w oil and that is what he put back in it. The trick to the oil change is you have to get every bit of air out of it or the shock gets to a point in the stroke where it "slips". The nitrogen charge was bumped from the factory 150psi to 200psi for my weight. You can bounce up and down on the bike and tell the difference. It only takes an 1/8th to 1/4 turn to make a noticeable change now. Will try it out next Saturday with the suspension guy there at the track. If it isnt quite right he will revalve it until it is. I thought that was pretty cool of him.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
posted January 08, 2010 08:09 PM
this is why i havent tried fvcking with mine lol. how do you take them apart ?
kawasakijockey
posted January 08, 2010 08:18 PM        Edited By: kawasakijockey on 9 Jan 2010 04:27
Glad I talked with some guys first because I like taking crap apart. I'd tear down a bowling ball if you gave me the time.lol
You have to bleed off the nitrogen with a syringe type needle and remove the bladder assembly. Pour the oil out and remove the cartridge assembly from the bottom of the shock. Yeah, it is worth paying somebody to screw with it who knows what is going on with tuning them.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
0.24525094032288 seconds processing time
