BIKELAND > FORUMS > ZX-14.com > Thread: brake fluid? NEW TOPIC NEW POLL POST REPLY
68gts2
hobbies ( Beating you !!! )
posted December 24, 2009 11:40 AM
brake fluid?
What fluid do the braks use? I am fixing to change the lines as part of winter improvements and forgot to look. Thanks
68gts2
posted December 24, 2009 11:57 AM
Its dot 4 if anybody wondered.
instag8tr
posted December 24, 2009 12:14 PM
i always use dot 5
zixxer14
Damn that was Quick
posted December 24, 2009 01:52 PM
there's brakes on these things?
Flame On
Fuel Air & Spark
posted December 24, 2009 02:41 PM        Edited By: Flame On on 24 Dec 2009 22:42
DOT 5 for mine I had brake fade on factory DOT 4 almost caused me to Weck . it was a hot day and I was using the brakes hard in the twistys DOT 4 didnt hold up
77 RD 400
80 GS1000 GT
06 ZX14
14nooby
posted December 25, 2009 08:33 AM
That's weird about the DOT5. Those fluids aren't interchangeable unless you flush the entire system really well. The factory spec is DOT4 which is sufficient brake fluid. DOT5 is a silicone fluid and is used in very limited applications.
Flame On
Fuel Air & Spark
posted December 25, 2009 09:59 AM
Yep completely flushed the DOT 4 and DOT 5 is much more expensive but brakes are too important for me. I also changed to braided brake lines
77 RD 400
80 GS1000 GT
06 ZX14
posted December 25, 2009 10:15 AM
pony up some bucks and get the MOTUL with the extended heat range, we blister that stuff on the race tracks
zixxer14
Damn that was Quick
posted December 25, 2009 11:25 AM
I always thought you couldn't use DOT5 in a system designed for DOT4. Makes for a mushy brake lever. How did it work out?
posted December 25, 2009 04:16 PM        Edited By: dubious on 26 Dec 2009 00:20
Motul RBF600 ....
0.37999200820923 seconds processing time
