BIKELAND > FORUMS > ZX-14.com > Thread: CHAIN LIFE???? NEW TOPIC NEW POLL POST REPLY
bbirdxx2000
posted November 15, 2009 04:17 PM
CHAIN LIFE????
Hi
I have a stock 2006 14, with 34,000 miles on her. It has the OEM chain. I notice I have to lube it more often and also adjust more. So when do I know when its time for a new chain
Thanks in advance
9.96 @ 143 stock with flies removed
dcjens
Wet side of Washington
posted November 15, 2009 04:30 PM
34K?? yeehaw! download the manual and find where you can measure a certain distance of links for service limit. 12.7 inches between 1-21 pins with a 20# weight to be exact. replace chain and sprockets together. 34K sounds like it served you well! change it!
Black 06
posted November 16, 2009 04:11 AM
That's a freakin lot of miles on a chain and sprockets!!
ave8er
posted November 16, 2009 07:10 AM
you have to change those?
posted November 16, 2009 09:39 AM
12500 on my oems so far...
posted November 16, 2009 10:01 AM
Your 1/3 of they way there bigdtd!!
Bad in Black
posted November 16, 2009 04:09 PM
The easy way to tell, is when you can pull a chain link more than half way off the rear of a back sprocket tooth, the chains done
INTIMIDA2OR
RED rider!
posted November 16, 2009 11:55 PM
34,000? Wow mine only got 32,000 . Usually when a chain is nearing its end it will be a bit noisy and will not hold its adjustment. Sounds like your chain is getting there .
'06 Passion Red ZX-14
*Lee*
bbirdxx2000
posted November 17, 2009 04:02 AM
thanks for all the replies, gonna take it to my shop Sat. and have my machanic look at it
Flame On
Fuel Air & Spark
posted November 17, 2009 07:49 AM
I got 35,000 k out of my last set motul oil every 600 miles
77 RD 400
80 GS1000 GT
06 ZX14
INTIMIDA2OR
RED rider!
posted November 17, 2009 01:04 PM
There ya go ! Also a chain is nearing it's end when one end of the chain is tight and one end is loose. That's the worst kind of a worn chain cause the loose side is really worn and is more likely to break than a chain that is worn evenly .
*Lee*
Artanis
stock
posted November 17, 2009 06:19 PM
I never got over 24K from an O ring chain. The thing was kinking and popping even with proper maintenance at 24K. With the X ring chain on my 08 ZX-14 I noticed that adjustments were fewer and less severe. Eight or so adjustments later I have 30K plus on my X ring chain and I decided to measure factory specs in three different places. The measurements were within factory specs only stretching 1\16 inch in 30K miles. The only problem now is that I have a minor kink in the chain even though we are within factory specs. I just ordered a DID 530 ZVM2 X Ring chain from Motorcyclesuperstore for $209.99. The chain might be a bit heavier than OEM and it is 120 links, not 116, but I am sure it will work well. I have a chain-breaker and a tool to seat the rivet link, so I think it will go well. I just did not want to push any further because the sprockets were still in good shape.
Artanis
posted November 17, 2009 06:46 PM
change the chain and sprockets at the same time!
0.30167698860168 seconds processing time
