BIKELAND > FORUMS > ZX-14.com > Thread: General questions that can help out other ZX14 owners.. NEW TOPIC NEW POLL POST REPLY
Rideharder
posted November 09, 2009 07:37 AM        Edited By: Rideharder on 9 Nov 2009 15:48
What kind of gears are you guys running on your bikes and what is your air pressure?
Also if you guys want to share your information on the feel and performance on lowering your ZX14 I would think this would be a great topic for other riders to base their opinions and be able to ask questions....... :-)
  Ignore this member    Click here to visit Rideharder's homepage.
Rideharder
posted November 09, 2009 07:46 AM        Edited By: Rideharder on 9 Nov 2009 15:49
More questions that you might be able to answer to help out members
What would be the best air pressure for the track
what would be the best air pressure for the streets
What's the best gear ratio for the track
what's the best gear ratio for the street
What's the best height performance for the track
what's the best height performance for the street
What would be the best gas to use for long trips
what would be the best on the track
what would be the best gas to race around off the track
What's the best overall exhaust for the drag strip
what's the best overall exhaust for the street
Bawls
re-learning to ride
posted November 09, 2009 08:17 AM
What would be the best air pressure for the track----- (dependant on track prep, tire, and wheelbase.)
what would be the best air pressure for the streets---- I run 30 front and 31 rear
What's the best gear ratio for the track------------(swb-17/40-41) (Stretched-16/43,44,45,46,47,48)
what's the best gear ratio for the street-----IMHO-16/41
What's the best height performance for the track-------in the dirt for the drags
what's the best height performance for the street------(SWB-stock)(stretched-2nd hole)
What would be the best gas to use for long trips-----87octane
what would be the best on the track-------87 octatne
what would be the best gas to race around off the track---87 octane
What's the best overall exhaust for the drag strip-------Anything from Brocks
what's the best overall exhaust for the street-------------Whatever suits you. I prefer Brocks
For techincal questions refer to Shane's build thread:
http://www.bikeland.org/board/viewthread.php?TID=40269&FID=27
For a good understanding on how far the zx14 has come refer to Brocks ZX-14 Diaries
Part1- http://www.dragbike.com/dbnews/anmviewer.asp?a=2079&z=2
Part2-http://www.dragbike.com/dbnews/anmviewer.asp?a=2196&z=2
part3-http://www.dragbike.com/dbnews/anmviewer.asp?a=2596&z=2
part3.2-http://www.dragbike.com/dbnews/anmviewer.asp?a=2649&z=2
Low end gains (about TRE And Removing the secondary flies on 06/07 models)http://brocksperformance.com/lowend.htm
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
Brockland Police Badge # 001
Bawls
re-learning to ride
posted November 09, 2009 08:30 AM
OH yeah... If you are going to lower your bike I strongly believe that you should put a lowered oil pan on it or at a minimum grind the tab off and put a flush mount drain plug like shane did. You can do a search on here and see that there have been a lot of people who have busted their oil pans resulting in crashes or near crashes. Here are some links of sites that are good for all of your zx14 parts buying needs .
shnitzracing.com -Not the best price on shipping, but good selection of parts
osrbikes.com Formerly Clems Kawasaki. Lowered oil pans and anything else you might need. Great customer service
brocksperformance.com IMHO the standard that all pipes should go by. Great customer service, bikeland member discounts, military discounts.
muzzys.com great pipes, decent prices, so-so customer service.
spencercycle.com Extensions, swingarm modification, good prices on SHINKO 003 U-softs.
there are a lot more but i'm out of time for now.
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
KikonZX14
Novice
posted November 09, 2009 09:42 AM
WOW!!! Great Info guys, thanks!!!
Feel the need for SPEED2007 ZX-14 Black with Red Flames (Helibars, Sliders, Yoshimura TRC Ti 4-2 Slip Ons, Fender Eliminator, Zero Gravity SR Windscreen, Custom Heel Guards , Speedohealer V4, Pazzo Levers -soon to come: Flies out / PCV w/A/T kit and later 16T sprocket)1990 Honda Steed (Japan model same as Shadow)1993 Kawasaki Vulcan EN 500 (gone as I trade it in for the ZX-14)Santiago, Chile, South America
derpie
Dont judge a book by its cover
posted November 09, 2009 10:39 AM
Why 87 octane ? isn't that too low of an octane to run this high hp bike on. Won't it knock or something bad or run lean ?
INTIMIDA2OR
RED rider!
posted November 09, 2009 10:54 AM
This should be a sticky
'06 Passion Red ZX-14
*Lee*
posted November 09, 2009 11:29 AM        Edited By: dubious on 9 Nov 2009 20:04
What would be the best air pressure for the track : 8-30 in the rear, 50 in frt (drag)
what would be the best air pressure for the streets: 30-34 rear ,35 frt for me
What's the best gear ratio for the track: depends on weight, power, ability, traction, distance
what's the best gear ratio for the street; 17/44 or 16/41 IMO
What's the best height performance for the track: as low as possible with out dragging parts or smashing the pan
what's the best height performance for the street : depends on your corner abilities
What would be the best gas to use for long trips; Premium
what would be the best on the track: depends on your tune. as low as possible without detonation
what would be the best gas to race around off the track : as low as possible with out detonation
What's the best overall exhaust for the drag strip: Brocks or tiforce IMO
what's the best overall exhaust for the street: as above
There are simply to many specific conditions to consider alot fo the time.
I like lower tire pressures for the traction, and actually better tire wear too.
However, rough roads need more air to protect the rim. A rim is 10 times as strong with a tire and 30 psi mounted, as it is bare. Thats part reason why I run more in the front, the other reason is I do not like tire squirm under the rim, especially on the front.
41 PSI is totally overkill, unless you ride at the GVWR of the bike., meaning 500 lbs of rider and passenger.
Bawls
re-learning to ride
posted November 09, 2009 11:43 AM
I refuse to run premium because the bike runs much better on 87 and I never ride like an old person. The way I see it... if it's not detonating we're good. I probably ride harder than most though.
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
Niner9
posted November 09, 2009 12:02 PM
"what's the best height performance for the street------(SWB-stock)(stretched-2nd hole)"
there's ride height on the 14???????????
Akro slip ons, Scotts Damper, Hel Brake & Clutch lines, Vortex Rearsets, Sato Frame Sliders, Power Commander, Custom Map, Flies Removed, BMC Race Filter, Marchenisi Rims, Corbin Seat, Ventura Pack Rack, Pazzo Levers, Zumo 550 GPS, Passport Radar Detector, Throttle Miester Cruise,
posted November 09, 2009 12:18 PM
I agree, I like 87 octane when it doesn't detonate, but too many times I have had it rattle.
I don't ride like a squid on a 600,.... so mine does see the torque curve and full throttle rolls away from traffic around town at 3-5k
Kawi recommends Premium.
Pump fuel can be inconsistant, and the general public wouldn't know detonation if it occured between their "bawls" LOL
The winter blend at the refineries begins as early as September here, and can last until April.
Thats when they dump excess hydrocarbon waste butane into the lower grade fuels,
Butane is a refining byproduct, without much demand, so they dilute low grade fuel with it.
The specific gravity is low, and so is the unstable flash point.
Even my 9:1 ford detonates on that junk.
So what works in Fla or Tx might damage an engine in Northern states or Canada....
Kawi has the 92 octane guidline for these reasons.
posted November 09, 2009 12:24 PM
Mine said 89 on the tank sticker ... Where does this 93 crap come from ? Doesn't really matter because i use 87 ...
BLK ICE
posted November 09, 2009 01:01 PM
Mine said 90+ on the tank sticker 07 ... I run 89.
posted November 09, 2009 01:07 PM
mine said 90+ as well... smokin they must have made a sticker specifically for you!
posted November 09, 2009 01:50 PM
sorry, it might have been 90 octane then, anyway.... the point I am making is my 9:1 ford detonates on low grade fuel here, and the ZX14 went into death rattle too.
derpie
posted November 09, 2009 02:08 PM
the only time i remember putting 87 in is when they were out of 93 and 89 i dont want to mess up nithing so i dont mind paing a little more
Rideharder
posted November 09, 2009 02:22 PM        Edited By: Rideharder on 9 Nov 2009 22:31
what's the best overall exhaust for the street-------------full TiForce Exhaust Systems
I use 93 octane my air fuel ratio is at idling 14.5 and when I'm on it it's at 13.5
I lowered mine in inch all around and have a brock strap up front which I think is the best strap for a zx14
For air pressure on the streets I use 38 upfront and in the rear 35
The best gear ratio for the streets I would say 16/41 and for the quarter mile I would say for my bike 17/44
Lowered in inch with my high-rise exhaust I'm still able to take the curves without bottoming out.
Rideharder
posted November 09, 2009 02:26 PM        Edited By: Rideharder on 9 Nov 2009 22:27
Thanks guys for your information keep it coming and I'll have a treat for you guys in the next two days.
Bawls, excellent information!
INTIMIDA2OR
RED rider!
posted November 09, 2009 02:30 PM
I use 87 with no probs.
*Lee*
posted November 09, 2009 02:46 PM
all you Cali and Fla guys get the good fuel year round.....
is there anything you don't get down there?
.... oh yaeh.... you don't get snow...... fookerssss.....
14nooby
posted November 09, 2009 02:57 PM
I only run 87. No it won't ping and yes it makes more power than 93
14nooby
posted November 09, 2009 03:00 PM
no government healthcare....lol
smokehouse4444
XX to ZX
posted November 09, 2009 07:25 PM
If your bike is tuned using 93, is that what it is going to run the best at, or will 87 or 89 still make it run a little stronger?
2008 Atomic Silver ZX-14, Brock's this and that, some other stuff, 260 in full gear, powered by Cheese
2005 Ducati 999 with all the goodies
INTIMIDA2OR
RED rider!
posted November 09, 2009 07:51 PM
Neener ,neener ,neener
*Lee*
smokehouse4444
XX to ZX
posted November 10, 2009 01:15 PM
Hello? Anyone? Anyone?
All times are America/Va [ This thread is 5 pages long: 1  2  3  4  5     Next» ] < Previous Thread     Next Thread >
0.25836300849915 seconds processing time
