BIKELAND > FORUMS > ZX-14.com > Thread: fuel pressure regulator NEW TOPIC NEW POLL POST REPLY
06redzx14
posted November 02, 2009 01:08 PM
anyone know how to modifiy fuel pressure regulator for more static pressure?
gilberjj
Friend of Fast
posted November 02, 2009 02:48 PM
Give it a good whack! I'll try and dig up the e85 thread where someone was explaining it in more detail.....
gilberjj
Friend of Fast
posted November 02, 2009 02:54 PM
Found it:
Here's the thread
http://www.bikeland.org/board/viewthread.php?FID=27&TID=50192&set_time=1254137668
here's the post
Roy, can you turn up the stock fuel pressure regulator? If so, how?
You can remove the regulator from the pump and shim the spring. Some folks have just hit the back side with a hammer ... I have to put a gauge on the pump to verify the pump pressure after I made the adjustment.
I have heard that this is hard on the the pump , so I only modified the pressure on the race bike .
Roy
0.24393010139465 seconds processing time
