BIKELAND > FORUMS > ZX-14.com > Thread: will these wheels fit NEW TOPIC NEW POLL POST REPLY
1969ca
posted October 30, 2009 02:05 PM
will 03-04 ZX6R wheels fit on a 04-05 ZX10
posted October 30, 2009 02:42 PM
Dunno, I thought the zx10 wheels were pretty light?
masszx14
A mind beside itself!
posted October 30, 2009 03:33 PM
Look up the parts fiche- if the bearings and axles o.d. match they will fit, you just have to reuse the axle sleeve (bearings inner spacer). Don't forget to check the brake rotors and if they are the same or if they have the same bolting pattern if different size.
If I remember right- the front won't fit because the zx10r uses a 25 mm front axle and the older 6r wheels were on a 20mm front axle. I could be wrong though.
Post on Kawiforums or search engine and look at threads around- plenty of everything on the bike forums.
universal@mind
0.66538500785828 seconds processing time
