BIKELAND > FORUMS > ZX-14.com > Thread: tiger tail NEW TOPIC NEW POLL POST REPLY
Bawls
re-learning to ride
posted October 25, 2009 08:03 PM
tiger tail
Holy crap... that thing was pretty much the biggest pain the ass that i've ever had to work with lol. I still have to do some trimming on the seat lock to get the plastic fasteners on the sides of the tail to line up correctly, but i set out to do it without pulling the rear wheel off or anything and succeeded so i guess that it's a win. Now all I have left to do is put the chain, extensions, sprocket, clutches, brocks clutch springs, oil pan, and racetech rear spring on lol. We'll just have to see how long all of that takes haha.
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
Brockland Police Badge # 001
posted October 26, 2009 03:22 AM
You can do all that in half the time it took just for the tail. I was told it would take 2 hours or so, but it was a PAIN!!
gilberjj
Friend of Fast
posted October 26, 2009 03:52 AM
I agree....... the tiger tail was a major pain. Good luck!
Bawls
re-learning to ride
posted October 26, 2009 05:03 AM
yeah, i got it in just under an hour and 45 minutes, but i was definitely yelling curse words at it in my parking garage lol.
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
Wheelie
Old Man
posted October 26, 2009 05:08 AM
rookies!
wee
posted October 26, 2009 05:21 AM
rookies!
wee
Ur right... We don't have 40 years experience under our belts.
1badvespa1400cc
power junkie
posted October 26, 2009 05:57 AM
Yeah but the end product looks nice,and you can also spray it with pam before you go to the track,so you can wipe the rubber right off!!!!!
Just another foeteen!!!!!
posted October 26, 2009 06:34 AM
Just make sure you don't let your tire touch the undertail! That would be bad.
I just leave the rubber on
Bently
2012 14r In Blue and no Mods!
posted October 26, 2009 08:00 PM
Never had to trim anything on my tiger to get it on. took about an hour with tire on.
Bawls
re-learning to ride
posted October 26, 2009 08:29 PM
i did mine without pulling the tank all the way off, and in a dim parking garage lol. I probably should have waited until i could use someone's garage.
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
Bently
posted October 27, 2009 04:42 AM
tank off? I never even lifted my tank.
Bawls
re-learning to ride
posted October 27, 2009 04:48 AM
if you never lifted your tank off, how did you pull the two bolts on the cross member to get the stock fender out and to bolt the tiger tail in?
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
Bently
posted October 27, 2009 05:23 AM
Bawla your right my bad. I did lift the tank
scotty
posted October 27, 2009 12:08 PM
Does it really help to have this, because I have rub a small quaurter size hole in my inner fender.
gilberjj
Friend of Fast
posted October 27, 2009 08:29 PM
It gives you a bit more clearance area so you can lower your bike even more.
Bawls
re-learning to ride
posted October 27, 2009 09:03 PM
and keeps you from rubbing through the stock plastic fender into the wiring harnesses and whatnot. It also does a really good job of pissing you off while trying to put it on. I suggest installing one just before an MMA fight. It would most likely give you the edge lol.
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
scotty
posted October 28, 2009 03:21 PM
Thanks fellas!
14nooby
posted October 28, 2009 03:49 PM
Well heres the bad news. I still rub my fender with a Tiger Tail and I also have my spring adjusted............Oh and I weigh less than 150. If you bought the Tiger Tail to reduce rubbing it will still rub. One perk is that your tire will not rub through it and it looks really good once installed.
posted October 28, 2009 03:57 PM        Edited By: Shane661 on 28 Oct 2009 23:59
Look at the following pictures. This is with the bike sitting at 63", and no adjustment between photos:
It looks to add around 1" of additional clearance:
In many cases 1" of extra clearance will be adequate to eliminate your rubbing issues. There are many factors, such as wheelbase, ride height, tire height, shock preload, etc. which can all contribute both positively and negatively. When I fitted mine, it did stop the issue.
posted October 28, 2009 07:02 PM
Mine has only touched once or twice, and on the tiger "tail" it stops your taillight from being covered in rubber. I like mine, but I'm with bawls, its a mo fo to install. I think I went in it not thinking that much...
14nooby
posted October 29, 2009 04:35 AM
Another factor to consider is how hard you launch also. Not stirring up trouble but I just find it weird that my spring is adjusted all the way down and my screws are all the way in and my tire rubs every pass. I love the tiger tail and it does give additional clearance. Maybe I will start hanging on to the clutch longer? Lol
posted October 29, 2009 04:56 AM
do what you do if your running in the 60's. obviously were not doing it right!
posted October 29, 2009 05:14 AM        Edited By: Shane661 on 29 Oct 2009 13:21
1" is 1"...the pictures don't lie. What height tire are you running, and where are your links set? Also...what is your wheelbase? Like I said, all of these things are factors.
Using threaded links you can lower the bike precisely. For example, just recently I lowered my bike by another 1". It started to rub, so I raised it back up about 3/8"...now it no longer touches. That would not be possible with the stock undertail.
Yes, just to make it clear: My 60 foots are mid 1.4's, consistently. Nooby runs low 1.4's consistently, and I think he has run some high 1.3's. So, keep that in mind. It might mean that 1" is no longer 1".
posted October 29, 2009 05:31 AM
I want to say I have close to 4 1/2" clearance. The tire is now closer to the flap hanging out the bacl than it is the actual undertail. I went to the back of the extensions yesterday.
posted October 29, 2009 05:50 AM        Edited By: Shane661 on 29 Oct 2009 13:52
It is quite dependent on where the tire is sitting. In my photos, the bike is at about 63"...which is normally in a very low part of the undertail. But, there is not as much leverage from the arm, either.
In Nooby's case, I believe he is sitting at 66"...which is really going to overtax the stock shock, making it even more likely to hit any undertail. I also believe he has a taller, road-race type of tire on the bike...that will eat up 1/2" or more in clearance as well.
Dusty, you may want to bend that flap upward if it looks like it will touch the tire under compression, that is what I do with mine.
0.31960201263428 seconds processing time
