BIKELAND > FORUMS > ZX-14.com > Thread: rear sprocket done already??? NEW TOPIC NEW POLL POST REPLY
MADNINJASKILLS
posted October 23, 2009 06:32 PM
Hey all:
I took my 14 out yesterday and when i got on it in first it sounded like the chain was popping or the wheel was going to come off. When I got it home, i looked at the chain and rear sprocket. The chain was adjusted correctly and at first glance, the sprocket teeth looked ok. as i spun the wheel, i found a couple teeth that looked bent in the direction of load. This is a Renthal 43 tooth alum sprocket with no more then 1k street miles. I havent had the bike on the track but do get on it from time to time. Im about 295 in gear and run a shinko 003. Is this normal to whack the teeth this soon?? I do hole shot the bike on the street but never had an issue with the stock sprocket. what gives??
Big Dave
2008 Atomic silver ZX14
2004 GSXR 1000
1998 Honda Valkyrie
davej
posted October 23, 2009 06:53 PM
I have one on my 14 with about 600 miles. Checks out perfect, this sprocket is made from 7075 T-6 aluminum. It will not tolerate heat above 600 degrees, If your adjustment was too tight this could be the problem. 295 in gear you may wish to thank a weak link over busting up more expensive engine parts.
Triumph guy
Flame On
Fuel Air & Spark
Aluminum teeth I will only run steal teeth on the mighty ZX14
77 RD 400
80 GS1000 GT
06 ZX14
MADNINJASKILLS
posted October 23, 2009 07:05 PM
what are you trying to say davej?? Flame on, what brand sprocket do you run? Anyone know if the sprockets that have an alum hub with steel teeth are any good?
Big Dave
2004 GSXR 1000
1998 Honda Valkyrie
Compton
posted October 23, 2009 07:19 PM
I got a Renthal 43t. when launching the bike it sounded like putting a huge card in spokes on a bicycle.
needless to say, i took off the sprocket and the noise went away.
b.w.
LAB3
posted October 23, 2009 07:24 PM
Driven Sprockets in steel. If it were me I would get a EKZZZ chain and new steel sprockets front and rear. OEM for front that has the dampner on both sides. I run 17/43
great street gears. Rivet master link.
zixxer14
Damn that was Quick
posted October 23, 2009 08:04 PM
Aluminum is too soft for sprockets, won't last even with hardening. Cheaper & easier to manufacture so aftermarket uses it. Only good if weight reduction is important or you need color in your life. Steel is Real!
MATTZ14
posted October 23, 2009 08:47 PM
I tore up a Vortex real fast. I was thinking about Driven as well. Got a good deal on a Renthal cause they ordered an aluminum and I wanted steal. Find out how long it lasts next season.
Later days, better lays
07 BLACK ZX14 Getting customized waiting for the white stuff to go away
06 BLACK ZX14 GONE Recall was a little late.
MADNINJASKILLS
posted October 23, 2009 09:22 PM
anybody have a link for driven sprockets in steel? All i could find was in alum?
2004 GSXR 1000
1998 Honda Valkyrie
MADNINJASKILLS
posted October 23, 2009 10:09 PM        Edited By: MADNINJASKILLS on 24 Oct 2009 06:14
i found the driven site but they only list a 41,42,43 selection. i have a 43 now and wanted to try a 45. Any suggestions on a 45 steel?
2004 GSXR 1000
1998 Honda Valkyrie
posted October 24, 2009 02:56 AM
I've ran vortex sprockets for years.. Never had a problem. Those are track and street miles.
Wheelie
Old Man
posted October 24, 2009 03:14 AM
Hey all:
Big Dave
how many miles were on the used chain when you installed the new sprocket?
wee
SteddyTeddy
posted October 24, 2009 06:24 AM
Same here. I run Vortex now even though I HATE Vortex as a company.
tnt
posted October 24, 2009 06:29 AM
I saw an Aluminum sprocket wad up like a pretzel last night! It was on a 6second drag Banshee , and it only had threeruns on the chain sprocket when it happened ! Luckily it was about 200 feet from the tree ,cause at 100mph that woulda hurt!! STEEL is best , Aluminum is , well , lighter , cheaper , uh aluminum!
MADNINJASKILLS
posted October 24, 2009 07:55 AM
Wee, the chain and sprockets were changed when i stretched it. about 1k ago. I had to adjust the chain a few times early on, but has been fine for a while. I lube it every other time i ride.
Thanks guys for all in info. This forum is awesome.
Big Dave
2004 GSXR 1000
1998 Honda Valkyrie
LAB3
posted October 24, 2009 08:30 AM
There use to be a shop that made steel sprockets any size. Damn I forgot the name
of the company. I will google and look around. Bored....... watching our sick German
Shepard.
MADNINJASKILLS
posted October 24, 2009 08:50 AM
Off topic but I have a shepard too. Great dogs. I grew up with them and will never be without one. I hope yours is ok!
Big Dave
2004 GSXR 1000
1998 Honda Valkyrie
INTIMIDA2OR
RED rider!
posted October 24, 2009 11:00 AM
+1 to steel sprockets !
'06 Passion Red ZX-14
*Lee*
bigwil
06 zx 14 turbo stage 3
posted October 24, 2009 11:23 AM
350hp i run vortex it works very smoth lk compton said the Renthal was crap IMO i snaped teeth right off mine.I never had a problem with a Aluminum votec sprocket caint see using a heavy steel IMO
if you run a chain to tight you were out bairrngs and were out sprockets and i see alot of loose chains on bikes and that wears the sprocket real fast KEEP UP THE MAINTENCE
bigwil// going fast aint easy so turbo it
INTIMIDA2OR
RED rider!
posted October 24, 2009 01:03 PM
Yikes! I've seen badly worn aluminum sprockets but nothing like that. The aluminum I've seen last pretty good on 600's. But the bigger cc's and HP tend to work them when you apply the miles to them.
*Lee*
LOCK 2121
posted October 24, 2009 04:01 PM
Having sevral big bore bike's being into drag raceing over the year's, long hiway mile's, dirt road's , no money , tried every combo , have had trouble with every alum. sprocket , exacpt billet solid vortex. Dirt as in the real world,freeway grit , wear's alum. faster, than steel
use only steel , extra hardend on the counter shaft , the strongest chain made, have damaged counter shaft bearing's running a bad sprocket before, had to get home , street raceing late at night GSX1100 katana, only 130 HP shreeded cheap sprocket with only 300 miles on it.!
Why I love this site, drag raceing, street rideing in hot wheather , most torture you can do to a bike ! ZX 14 hold's up well.
LAB3
posted October 24, 2009 04:06 PM        Edited By: LAB3 on 25 Oct 2009 01:29
Big Dave
He is almost 5 and just had a complete hip and socket replaced....sigh.
But we caught it soon enough he wil be good as new in a few months. :-)
My email labartay@verizon.net
Louis
INTIMIDA2OR
RED rider!
posted October 24, 2009 04:11 PM
Hell yes!
*Lee*
davej
posted October 24, 2009 04:18 PM
Replaced today with steel, I was wrong. More wear than the steel with 32K miles.
Triumph guy
Bad in Black
posted October 24, 2009 04:35 PM
I don't run aluminum on the street, seen and had too many problems with them. Steel only....
0.24793386459351 seconds processing time
