BIKELAND > FORUMS > ZX-14.com > Thread: Thinking of a turbo NEW TOPIC NEW POLL POST REPLY
01smokes
posted October 10, 2009 06:29 PM
Thinking of a turbo
well its time to step it up ether a big motor with some spray or a turbo kit at around 6-10psi what would you guys do and what turbo kits have you guys had luck with for the 14?
PayPal, vigilart22@yahoo.com
Email, artvgl@yahoo.com
posted October 10, 2009 06:31 PM
Sorry forget the turbo and go with a small shot ...
01smokes
posted October 10, 2009 06:37 PM
you were on a 30 shot right??
posted October 10, 2009 06:39 PM
i love to hear a turbo'd bike... ive never got to ride one.
posted October 10, 2009 06:40 PM
Yup 30 shot ..
01smokes
posted October 10, 2009 06:45 PM
Yup 30 shot ..
im on a 40 shot now with a progressive controller and it works good, but im just getting bored i guess, maybe i should put springs in and hit it with a 60 shot and call it a day
davej
posted October 10, 2009 07:11 PM
Stock exhaust weighs 40 lbs the turbo weighs 43 lbs. I'm sure the NOS reduces your weight quite a bit which in turn improves reliability. Turbo death will bite you if you make one boo boo. I have 25,500 miles on the turbo and 35,000 miles total. Just added a 7# spring and remapped. Made 250.3 hp and torque lined out at 5,000 rpms at 138 ft. lbs. It is a costly system around $6K.. Have to try the Shinko slick and readjust gears and swing arm length. Sure it will make the 8's now but listen to Smokin when it come to common sense.
Triumph guy
oldkawboy
posted October 10, 2009 07:17 PM
Nuttin like that tunnel vision when you're building boost ! :-)
Dan
Compton
posted October 10, 2009 08:06 PM
different turbos have different weights.
do a 10.5:1 compression stout engine setup with a 200 shot. that would would be fun
b.w.
davej
posted October 11, 2009 12:37 AM
Turbo weight varies, this is for Turbonetics T-3/4. There is a video on You Tube search for ZX14win. and it will pop up.
Triumph guy
NINJA12
posted October 11, 2009 03:28 AM
If you mean 6psi on pump and 10psi on c16 then it should be easy.
I've sprayed wet and dry , on stock and built motors, over the years.
Just like nitrous big hp requires big investments.
Cost wise it's not much difference for a built motor and spray vs a stage 1 turbo on stock motor. Big motors don't usually do well for street rides and need more rebuilds, where a low boost turbo can go anywhere and last longer between builds.
I got bit when I turned the turbo up on pump gas, but I also got bit with nitrous .
Stage 1 @ 6psi should be around 240-250 hp. What Hp would you target with your build?
0.26753520965576 seconds processing time
