BIKELAND > FORUMS > ZX-14.com > Thread: spun a bearing NEW TOPIC NEW POLL POST REPLY
busa
posted October 08, 2009 06:23 PM
spun a bearing
my freind spunn a bearing on his busa. he had the bearing replaced about 5 month ago. i guess the guy who did the work did a bad job. how hard is it to pull the motor? only one way to learn. im about to give it a shot . just looking for some good tips. thanks in advance
  Ignore this member    Click here to visit busa's homepage.
06redzx14
posted October 08, 2009 06:27 PM
gonna need to have the crank worked
busa
posted October 08, 2009 06:30 PM
why you say that? the crank looked good last time the bearings were replace. i was thinking about just buying a used bottom end.
Douglas Home
posted October 08, 2009 06:37 PM
With a Busa , I'm sure you need head work, and about your used bottom end?
Love always!!!
Doug Mackay Australia
Compton
posted October 08, 2009 07:32 PM
2 hour job
b.w.
zxbob
posted October 08, 2009 07:46 PM
If the crank was not set up properly when the work was done, I highly doubt it would
take five months for it to show up. Look for what may have caused the problem, there's
a reason in there somewhere.
Bob
Bad in Black
posted October 08, 2009 08:57 PM
lackaoil.....
posted October 09, 2009 03:00 AM
Trash the busa and buy a 14
BobC
posted October 09, 2009 03:41 AM        Edited By: BobC on 9 Oct 2009 11:53
lackaoil.....
That's what I would have said too. For a shell bearing to spin the friction between the crank journal and the bearing has to be greater than the friction between the con-rod and the bearing, usually lack of lubricant. As long as the previous work was carried out correctly......were the crank journals checked to make sure they weren't out-of-round? Are the con-rods straight? All that stuff needs checking and it might even be worth having the crank re-ground if you're going to all the trouble of taking the engine apart.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
busa
posted October 09, 2009 08:32 AM
Bob
i talked to the guy who did the work he said no that couldnt happen its all new parts in their. i know about two people who he build motors for and spunn bearing just found that out .
busa
posted October 09, 2009 08:33 AM
lackaoil.....
the first time it spunn a bearing was lack of oil. the second time it had oil. we checked it before riding
busa
posted October 09, 2009 08:43 AM
we already have two 14s. the busa was a friends but he was not making the payments so had to take it from him. he was messing up my credit. now im stuck with a busa lol ill try to make it look nice lol
busa
posted October 09, 2009 08:46 AM
lackaoil.....
thats why i just feel like buy a used bottom end and replacing the rings and piston if needed. dont want to go threw this again
0.23184299468994 seconds processing time
