BIKELAND > FORUMS > ZX-14.com > Thread: boring out the zx14 NEW TOPIC NEW POLL POST REPLY
Trell
Lets ride
posted September 27, 2009 08:02 PM
boring out the zx14
i need more power out of my bike. what is the max bore i can do?
30df7881
posted September 27, 2009 08:09 PM
3 mill ... better to stroke it 4 mill and leave the bore STD ..
Trell
Lets ride
posted September 27, 2009 08:16 PM
how much more will it add?
30df7881
MJ
posted September 28, 2009 02:54 AM
Just boost it, easier and more bang for the buck.
BobC
posted September 28, 2009 06:11 AM
I don't think there's enough material between the bores to take it out much. Better to go for a stroker.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
Compton
posted September 28, 2009 06:48 AM
235+ 1570 Stroker, CNC Head Porting/Custom JE Pistons/ Carillo Rods/ Custom Big Camshafts/ Tappets Mod w Tappets/ High rate Valve Springs/ Retainers/Auto Cam Chain Adjuster, and Clutch Mod. $8500
http://www.carpenterracing.com/zx14.htm
here ya go
b.w.
NINJA12
posted September 28, 2009 07:09 AM
Is that parts or drive in and drive out price?
06redzx14
posted September 28, 2009 07:20 AM
drive in/out
INTIMIDA2OR
RED rider!
posted September 28, 2009 10:12 AM
Wow stroker is nice but geez boost is cost effective!
'06 Passion Red ZX-14
*Lee*
posted September 28, 2009 10:16 AM        Edited By: Shane661 on 28 Sep 2009 18:17
3mm is the max bore, 2mm is what Millenium prefers/suggests.
A 2mm bore is a 1417, a 3mm is a 1450 with stock crank. A 4mm crank alone will net you a 1441 and keep the stroke to a reasonable 65mm.
06redzx14
posted September 28, 2009 11:03 AM
has anybody seen one of these 4 mil strokers live on the street? the last guy that told us about them didn't check out so well
BIG BLUE_ZX14
posted September 28, 2009 11:34 AM
Holy horsepower batman. The info on that page made me drool...now if only i was rich.
2007 Blue ZX14 Gone...
BIG BLUE_ZX14
posted September 28, 2009 11:37 AM
Is that a drop in mod? Can you simply R&R the crank or if you do replace the crank it requires you to do other mods as well...like timing?
posted September 28, 2009 11:43 AM
You need pistons with relocated wrist pins, or shorter rods.
Probably smart money to do crank, pistons, and rods at the same time. There is plenty to be done besides just replacing the crank.
Trell
Lets ride
posted September 28, 2009 11:54 AM
so if i got 65mm ill be safe and happy...lol
30df7881
Hurricane
posted September 28, 2009 12:08 PM
What is the rpm limit on a stroker?
06redzx14
posted September 29, 2009 10:18 AM
called adam's it is 1750 for pistons and stroker crank, but it is a month wait until they see the crank again.
Fastest-14
Fastest -14
posted September 29, 2009 07:58 PM
Yeah but my biggest question is, how streetable is this 4 mil stroker mod. Builders keep telling me that it's better to go wit a 2 mil bore and leave the crank alone if it's going to be a street bike because stroking is very hard on the bearings. You don't have that issue with boring.
Flyboy
posted September 29, 2009 08:45 PM
Got 238-240 hp on my dyno with my wet nitrous setup. A lot cheaper and motor will last longer. (If you don't abuse the nitrous)
"The World's Fastest Indian"
One fast red ZX-14,
Axel from Germany
posted October 01, 2009 10:57 AM
And no, wath we can do ?
And now, what can we do to drill 3 mm are problems with the head gasket. Crank more hub does not hold.
Fastest-14
Fastest -14
posted October 01, 2009 10:03 PM
Huh?
Axel from Germany
posted October 02, 2009 12:01 AM
Huh?
The difference with USA is that we can drive in Germany is not only a quarter of a mile at full speed. A tuned engine must withstand 10 KM 20 KM throttle.
The tuner in Germany say that one can not stand Muzzy Crank that.
A 3 mm boring is not ideal, because it blow the head gasket.
0.32155799865723 seconds processing time
