BIKELAND > FORUMS > ZX-14.com > Thread: Stock air filter NEW TOPIC NEW POLL POST REPLY
rich s
posted September 24, 2009 05:32 AM
Stock air filter
With tomorrow being the big day I thought I should check the air filter. Good thing I did as it had about two pounds of bug parts in it. I tapped out as much as I could and used the air compressor for the rest. There was a little bit of oil residue but I think that is normal.
Next week I will get a high flow for the track. Should I switch back and forth to the stock filter for the street? Do I need a different map from Brocks for each one? How many times can I just clean the stock filter?
posted September 24, 2009 08:02 AM
With the stock paper filter I'd bet your not getting the "full amount" of air through it, even though you blew it out. The paper still has dirt stuck to it, therefore allowing it not the breathe as good.
posted September 24, 2009 08:03 AM        Edited By: Shane661 on 24 Sep 2009 16:04
Plus, the metal grating is obviously restrictive. A less restrictive street type filter should work well for you, without needing to swap them.
I use a BMC race if I am going to do any longer street rides, but I have been known to run without at the track.
rich s
posted September 24, 2009 08:19 AM
Shane would the K@N be the right choice then? I don't want to take it out completely since it is pretty dusty there (no pun intended eklipse636). I have not put the stock filter back in yet, should I just cut the screen off the back and be done with it?
posted September 24, 2009 08:23 AM
BMC makes a street filter as well as K&N. I have used both BMC and K&N products with success in the past. I have not tried either of their "street" filters for the 14, though.
posted September 24, 2009 08:34 AM
none taken. I was going to take my filter out next time I was at the track, but the more I thought ab it, I said naah bc after running at night I have more bugs on my helmet than I do while street riding.
Newf14
2007 ZX1400
posted September 24, 2009 08:44 AM
I use the K&N in my 14 and I find it really good. I took it out once to inspect for dirt getting past it around the edges everything was fineit seals well and comes with the K&N sealing grease which I used a little of as well.
Newf14
Bently
2012 14r In Blue and no Mods!
posted September 24, 2009 10:05 AM
I've always read and heard that kn is not the best filter for the track as it is more restrictive then say a BMC or piper cross. kn's where known in the past to lose hp on the dyno.
posted September 24, 2009 10:09 AM
I've heard the stories of kn being lower on dyno's than the others as well.
rich s
posted September 24, 2009 10:13 AM
I will go with the BMC street filter. I have not found any negative comments about BMC.
derpie
Dont judge a book by its cover
posted September 24, 2009 10:20 AM
I wasn't aware that you could clean the stocker it had to be replaced when dirty.... right?
Bently
posted September 24, 2009 10:23 AM
Ya he just blew it out, I have the piper cross race and am happy with that as well.
INTIMIDA2OR
RED rider!
posted September 24, 2009 04:34 PM
BMC street filter for me
'06 Passion Red ZX-14
*Lee*
0.25652408599854 seconds processing time
