BIKELAND > FORUMS > ZX-14.com > Thread: bike wont start NEW TOPIC NEW POLL POST REPLY
busa
posted September 20, 2009 11:54 AM
bike wont start
A FRIEND OF MINES WAS RIDING HIS BIKE HE SAYS HE BOTTOM OUT A LITTLE HIT THE OIL PAN NOTHING BIG. PAN LOOKS GOOD. ALL OF A SUDDEN HIS OIL LIGHT STARTED BLINKING. HE NOTICE THE BIKE STARTING TO SLOW DOWN . HE PULLED TO THE SHOULDER AND BIKE TURN OFF. AT FIRST THE BIKE DIDNT WANT TO CRANK AND THE TEMP KEPT ON BLINKING SO WE THOUGHT THE BIKE OVER HEATED. WAITED ABOUT HALF HOUR BIKE STARTED TO CRANK BUT WONT TURN ON TEMP STILL BLINKING UP AND DOWN. DOES ANY ONE KNOWS WHAT MIGHT BE THE PROBLEM ? THANKS GUYS
  Ignore this member    Click here to visit busa's homepage.
Superman T
posted September 20, 2009 01:01 PM
Maybe the shop could assist. All caps request,no make/model,and previous sarcasm to the fullest. Advise that many consult with shops/dealers because they need help...
Superman T
posted September 20, 2009 01:06 PM
Maybe the pic off that faded bike might get some info...
posted September 20, 2009 01:22 PM
Lol
INTIMIDA2OR
RED rider!
posted September 20, 2009 03:26 PM
Busa won't start?
'06 Passion Red ZX-14
*Lee*
Flame On
Fuel Air & Spark
posted September 20, 2009 03:35 PM
Try push starting it
77 RD 400
80 GS1000 GT
06 ZX14
Bad in Black
posted September 20, 2009 03:39 PM
...........over a cliff
Flame On
Fuel Air & Spark
posted September 20, 2009 03:41 PM
or under a troll bridge
77 RD 400
80 GS1000 GT
06 ZX14
INTIMIDA2OR
RED rider!
posted September 20, 2009 03:55 PM
Any oil or water in the bike?? . Check the connections to the ecu.
*Lee*
masszx14
A mind beside itself!
posted September 20, 2009 05:01 PM
Put some in the gas tank and then try to push start it.
universal@mind
QWICK
posted September 20, 2009 05:10 PM
Hook that Busa to a 14 and it'll run like Hell.
Seriously though, if you have a PCIII installed, check the ground wire to ensure a good connection. That has been the culprit for many.
busa
posted September 20, 2009 05:20 PM
THE ECU WENT BAD . I TRIED IT ON MY BIKE AND IT DID THE SAME THING THE TEMP STARTED BLINKING WONT START PUT MY ECU BACK ON AND MY BIKE TURN RIGHT ON. BUT NOW THE BIKE WONT POWER UP . THE BIKE HAS A ALARM IDK IF THAT WOULD BE THE PROBLEM. THEIR WAS SOME MELTED WIRES BUT THEY REALLY WERENT CONNECTED TO ANY THING .
busa
posted September 20, 2009 05:23 PM
it got gas, i hooked some cables to the battery but i get nothing no power.
busa
posted September 20, 2009 05:29 PM
that would cause the bike not to power up. all i did was disconnect the ecu now i get no power
masszx14
posted September 20, 2009 06:10 PM
Your caps lock key seems to get stuck every now and then
universal@mind
posted September 20, 2009 06:13 PM
If it melted wires you got more wrong than a ecu... Wires done melt for no reason. what wires do you have on the bike "that don't go to anything"?? Is it just a few extra wires kawasaki decided to throw in for free?
P.s. WE CAN READ LOWERCASE LETTERS JUST AS GOOD AS CAPS!! NO NEED FOR YELLING ALL THE TIME!!!!! Hope you find the problem
masszx14
posted September 20, 2009 06:59 PM
Myself and Salsa would recommend a prayer and/or
an animal sacrifice!
universal@mind
busa
posted September 20, 2009 07:56 PM
the loose wires that are a little melted are the ones that got to do with the alarm but they werent connected to any thing. it looks like my friend burn a hole threw the under tail and started rubbing the ecu. its a big hole. hmm... would the ecu cause it not to power up maybe the clips are bad. all i did was disconnect the ecu
busa
posted September 20, 2009 08:42 PM
bikeland
how about now could i get some info lol
Wheelie
Old Man
posted September 20, 2009 08:44 PM
busa, you're gonna get allot of flap here, just hang in there and it will pass.
wee
busa
posted September 20, 2009 08:46 PM
wee
i hope so.
KikonZX14
Novice
posted September 21, 2009 07:22 AM
Se cosecha lo que se siembra Busa. Paciencia y ya pronto pasará.
Saludos,
David
Feel the need for SPEED2007 ZX-14 Black with Red Flames (Helibars, Sliders, Yoshimura TRC Ti 4-2 Slip Ons, Fender Eliminator, Zero Gravity SR Windscreen, Custom Heel Guards , Speedohealer V4, Pazzo Levers -soon to come: Flies out / PCV w/A/T kit and later 16T sprocket)1990 Honda Steed (Japan model same as Shadow)1993 Kawasaki Vulcan EN 500 (gone as I trade it in for the ZX-14)Santiago, Chile, South America
rich s
posted September 21, 2009 07:55 AM
Since you are the person trying to start it I would guess it is one of these two problems.
1) The key is not turned on before you press the starter button.
2) You are trying to start it with the key alone (like a car).
Turn the key to the on position and wait 2 seconds. At this point the dash will be lit up. Now press the starter button. Hold it down until the engine starts but be sure to release it immediately after start up. There is a warm up cycle but that will be too much for you to understand so just wait about 2 minutes after start-up before driving.
One more thing, if it keeps dying on you when you put it into first gear you will need to put the kick stand up. The kickstand is what is holding the bike up when you are not on it. It is on a hinge so you can flip it up before driving. Because Kawasaki knows people like you will be buying this bike they put in a fail-safe so the bike will not drive with the kickstand down.
If you are having a hard time reaching the grips once started it means you sat on the bike backwards. Put the kickstand back down, get off the bike turn 180 degrees and get back on. From here you should be able to see the speedometer and tach.
Let me know if you need anything else. Your friend,
Rich S
busa
posted September 21, 2009 08:08 AM
Rich S
thanks richy rich
rich s
posted September 21, 2009 09:33 AM
Your welcome Needsagreencard
0.22201085090637 seconds processing time
