BIKELAND > FORUMS > ZX-14.com > Thread: Cut down oil pan NEW TOPIC NEW POLL POST REPLY
1badvespa1400cc
power junkie
posted September 03, 2009 11:35 AM
Cut down oil pan
Where is the thread where it tells you how much to cut down the pickup tube and also is it possible to hook up a oil presseure gauge?
Just another foeteen!!!!!
kawasakijockey
posted September 03, 2009 11:54 AM
You can install a 1/8 branch tee at the oil sending unit for a pressure guage.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
zx14turbo
truth....thats all i ask
posted September 04, 2009 02:45 AM
you can install an oil pressure gauge at the sending unit. there are also a couple of other places that see oil pressure that are drilled tapped and plugged. you can put a reducer in place of the plug and run your gauge from there as well. one is below the timing advance/ crank sensor.
you can call osr/clems Kawasaki and ask. you want the p/u around 1/8-1/4 inch from the bottom so as not to touche the pan but will be under oil at all times. the stock pans have the pick up shortened by hand and not machine so the distance varies a little from length to length.....as long as you are close you are good.
zx14turbo
Warlord
posted September 04, 2009 04:43 AM
Where is this located? Any pics?
WarLord
04 Black ZX10R (Sold)
09 Green ZX14 (Sold)
Warlord
posted September 04, 2009 04:46 AM
Any pics?
WarLord
Compton
posted September 04, 2009 04:55 AM        Edited By: Compton on 4 Sep 2009 12:56
I put a Defi Oil Pressure gauge on my dash with the sender on my pan. Its the tee-d off the oil pressure "switch" next to the oil filter on the front of the pan.
it's a not a true 1/8th npt fitting, so be ready to re-tap it or buy the correct fitting from cycle logic.
http://www.cycle-logicmotorsports.com/index.php?main_page=product_info&cPath=6&products_id=53&zenid=f9f669529c5221f09208955a2185db18
I just re-tapped my pan.
b.w.
kawasakijockey
posted September 04, 2009 05:04 AM
That fitting is the way to go.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
Warlord
posted September 04, 2009 05:42 AM        Edited By: Warlord on 4 Sep 2009 13:45
http://www.bikebandit.com/assets/schematics/Kawasaki/KA1008061044.gif
would this be it #27010 ?
WarLord
kawasakijockey
posted September 04, 2009 06:15 AM
yep, that is the oil pressure sensor.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
Warlord
posted September 04, 2009 06:20 AM
Thanks. Just wanted to make sure I got the right one>
WarLord
1badvespa1400cc
power junkie
posted September 04, 2009 10:48 AM
Thanks for the info guys!!!!
0.29020977020264 seconds processing time
