BIKELAND > FORUMS > ZX-14.com > Thread: !!!!!!!!DYNA SHIFT LIGHT!!!!!!! NEW TOPIC NEW POLL POST REPLY
1badvespa1400cc
power junkie
posted August 27, 2009 06:04 AM
How does it hook up again I know there was a post about it but I cant find it,any help would be appreciated,also wich shift minder hooks up to one coil wire,someone posted up awhile back about using two wires?
Just another foeteen!!!!!
jdrill04
posted August 27, 2009 06:24 AM
I had to use two wires on my dyna shift light. I used the #1, and #4
1badvespa1400cc
power junkie
posted August 27, 2009 06:31 AM
Whats the #1,and#4,on the coils and if so what color?
jdrill04
posted August 27, 2009 07:47 PM
I will have to look at the color of the wires , but schnitz sells a plug and play for the coils that is what I used. The #1 is the coil on the left side if you are setting on the bike. The #4 is the coil on the right side.
Douglas Home
posted August 27, 2009 08:29 PM
From memory use the striped wire
Doug Mackay Australia
1badvespa1400cc
power junkie
posted August 28, 2009 06:21 AM
Talked to chris jones and he is hooking up one and is going to let me know where to tap into for a good signal,thanks for the info .
AcadianaZX
Advertiser
posted August 28, 2009 06:33 AM
+1
1badvespa1400cc
power junkie
posted August 28, 2009 01:53 PM
Looked on their web site and the tach adapter will not work as per their hookup directions.
jdrill04
posted August 28, 2009 08:09 PM
They have coil adapters that plug right into the coils and then you take the # 1 coil and #4 coil. This way you dont have to splice into your coil wires. I still have them in the shop if you are intrested.
busa
posted August 28, 2009 08:33 PM
bikeland
  Ignore this member    Click here to visit busa's homepage.
1badvespa1400cc
power junkie
posted August 31, 2009 05:31 AM
How much?
jdrill04
posted August 31, 2009 05:54 AM
Make me a offer they are just setting there. I will put my hands on them today , and make sure I can find them.. If you want contact on my email JDRILL04@AOL.COM
0.40580296516418 seconds processing time
