BIKELAND > FORUMS > ZX-14.com > Thread: Turbo exhaust manifold to exhaust pipe flange NEW TOPIC NEW POLL POST REPLY
JDC
posted August 18, 2009 08:52 AM
My turbo and exhaust stuff should be here in a day or two and for the re-install I was thinking of putting some type of gasket between the turbo exhaust manifold to exhaust pipe flange. I believe the union was made to do without one, but seems like having one would better ensure no leaks in the future.
Anyone with some practical experience with this type of idea?
Thanks.
Compton
posted August 18, 2009 11:19 AM
so exhaust housing to downpipe?
b.w.
posted August 18, 2009 11:38 AM
Flange to turbo and down pipe i use High Heat RTV ( The copper colored stuff ) Never had a leak ..
JDC
posted August 18, 2009 12:06 PM        Edited By: JDC on 18 Aug 2009 20:06
turbo exhaust flange outlet to exhaut pipes inlet flange, yes.
smokin, rtv is silicone or paint?
tks
posted August 18, 2009 12:09 PM
tks
silicone
JDC
posted August 18, 2009 05:06 PM
Gracias.
gilberjj
Friend of Fast
posted August 19, 2009 07:56 AM
The problem with that stuff is it's a mess when you take it apart.
I like actual gaskets cause they don't make a mess, and you can reuse them sometimes.
http://www.prostreetonline.com/s/turbos_turbo-gaskets.asp
JDC
posted August 19, 2009 12:37 PM        Edited By: JDC on 19 Aug 2009 21:58
gi
I would prefer a hard gasket, but the shape of the outlet is not standard as far as I can tell.
Compton
posted August 19, 2009 01:30 PM
something like this?
http://cgi.ebay.com/ebaymotors/Garrett-T25-T28-NISSAN-Silvia-outlet-gasket_W0QQitemZ120455535511QQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?hash=item1c0bb59b97&_trksid=p4506.c0.m245
b.w.
JDC
posted August 19, 2009 02:01 PM        Edited By: JDC on 19 Aug 2009 23:27
Compton, that is perfect! thank you.
Looks like a match.
I have a GT 30... know if it is the same dimension?
NM.. for the price I ordered one and will let you all know if it fits..
Tks again Compton.
sized and overlayed
Obba
posted August 19, 2009 05:17 PM        Edited By: Obba on 20 Aug 2009 01:18
Nice Photoshop or Corel Pain work there!
Compton
posted August 19, 2009 05:29 PM
in the ebay ad the 2nd images it gives the diaminsions of the gasket, maybe that will help?
b.w.
JDC
posted August 19, 2009 05:30 PM
hey tks.. just grapped a photo off internet of gasket, sized, placed and color'd it.
Looks like something from my K grade days!
zx14turbo
truth....thats all i ask
posted August 21, 2009 03:47 PM
all you have to do is use the copper high temp silicone and let it be, its been my experience on cars that the paper gaskets blow and the copper stays sealed. just check the bolts after a few heat cycles and you will be good to go.
zx14turbo
JDC
posted August 21, 2009 03:48 PM
That may be what I have to do, as one of the gaskets I ordered specifically for the Garret 30 turbo was too big...!
zx14turbo
posted August 22, 2009 04:04 AM
just apply the copper rvt, let it set up a few min...bolt up the down pipe and you are done. dont worry about the gasket, you do not need one. your search for a fix is over. hope this helps. it will even seal in applications that the two mating surfaces are not perfectly machined to fit one another.
zx14turbo
JDC
posted August 22, 2009 05:36 AM
Yes, I'm off this am for get some RTV!
0.22732210159302 seconds processing time
