BIKELAND > FORUMS > ZX-14.com > Thread: 06-07 vs 08-09 Fuel pumps NEW TOPIC NEW POLL POST REPLY
Big_T112
posted August 16, 2009 06:41 PM
I changed the Fuel pump in my 07 gas tank to one of the new 09 pumps that don't have the sump on them. looking at them side by side they are two different pumps. It runs fine but had some really rich areas in the map it didn't have before the 09 pump. Anyone else experience this or have made the swap?
Compton
posted August 16, 2009 06:49 PM
the pump in the 08-09 is a lot smaller in size. flow should be controlled by the intake regulator. I don't know of 08-09 bikes running at higher pressures.
b.w.
Big_T112
posted August 16, 2009 06:57 PM        Edited By: Big_T112 on 17 Aug 2009 03:01
Don't they have higher flow rate injectors on the 08-09? regulator is in the pump housing.
posted August 17, 2009 04:46 AM
My 07 runs great with an 08 pump, but I didn't dyno it before. The only very rich areas in the map were in the low rpm (under 5k rpm, if I recall), which I think is normal for a Brock's race map?
But it runs great at the track...
wrongway
posted August 17, 2009 07:04 AM        Edited By: wrongway on 17 Aug 2009 15:04
the manual for the '06 says the pump ressure is 44 psi. what doe an '08 or '09 manual say the fuel pressure is ?
Roy
0.28420305252075 seconds processing time
