BIKELAND > FORUMS > ZX-14.com > Thread: Seat padding NEW TOPIC NEW POLL POST REPLY
Douglas Home
posted August 15, 2009 01:18 AM
Seat padding
I've just picked up a very cheap never used seat.
I'm on a budget so am going to reupholster it myself, just for the track and keep the stock one for road use, so I'm not worried about comfort.
My plan is to remove the vynal , then cut and remove the padding in front of the higher rear section, leaving the original rear profile to fit the rear cowling with no gap.
Then use as thin a layer of foam as possible to get lower without the expense of a catalist seat! I will reuse the original vynal cover.
Never done this before so looking for hints on what type / thickness of foam to use etc.
Doug Mackay Australia
Douglas Home
posted August 15, 2009 02:05 AM
Another question , should I glue the new foam to the seat base?
Wheelie
Old Man
posted August 15, 2009 05:11 AM
yes.
wee
Wheelie
Old Man
posted August 15, 2009 05:12 AM
1/4-1/2
wee
Lucky14
posted August 15, 2009 05:22 AM
yes.
wee
Soooooooooo, did you redo your "very cheap never used seat" yet?
Douglas Home
posted August 15, 2009 05:32 AM
Not yet mate, it hasn't been delivered yet.
Wee , thanks for the advice.
kaw-rick
posted August 15, 2009 05:56 AM
i thought catalyst seats were cheap. shit a stock zx14 seat usually runs $100 used.
Douglas Home
posted August 15, 2009 06:55 AM
Aust $100 off a forum sponsor over here that has 2 zx14's.
It came off one he set up for racing, never met him, but have heard he is a stand up guy.
It will work out heaps cheaper for me and be quick and easy to swap over.
I'm just a test/n/tune racer with dreams bigger than my capabilities and budget!!!
As far as I know I have the worlds slowest nitrous 14!
You Americans are lucky , cheaper parts and in stock! Everyone here is a bloody Busa lover!
posted August 15, 2009 08:24 AM
Get the firmest foam you can find, if its thin no problem just double or tripple stack it with glue...
I recommend sitting on the plastic base of the seat while its on the bike and get a feel for it, MAKING the seat as comfortable as possible by putting padding in the center only...
Wheelie
Old Man
posted August 15, 2009 09:14 AM
yes.
wee
I talked with the upholstery guy at work today about it, you racing tonight?
wee
Douglas Home
posted August 15, 2009 10:55 PM
My next race is on the 22nd , I'm in Aus so might not be seeing you there!!!
Thanks for the help.
0.26234698295593 seconds processing time
