BIKELAND > FORUMS > ZX-14.com > Thread: Better Map? NEW TOPIC NEW POLL POST REPLY
Acat
posted August 13, 2009 06:01 AM
Better Map?
07, no flies, 4 degree advance,PC,TRE, 17/43, stock filter and exhaust. Using no flies map per DynoJet. Anything better out there? Does this map run rich or lean on top or bottom?
LAB3
posted August 13, 2009 06:51 AM
With stock exhaust you are fine. Some slip on's will help a little but I would wait
and replace the complete exhaust system. Yosh, Brocks. Muzzy M14, Akrapovic all are
good systems. Your question on lean/rich will vary as the altitude will make a difference.
A good street map is usually a little rich so it is smooth. Do you notice any black smoke ?
TRE on stock exhaust??
Did you buy the 14 set up this way? If so I bet it had a full system on it before you got it.
Acat
posted August 13, 2009 07:07 AM
Flies were gone when I got it w/1k miles. I added the rest. No smoke. No TRE w/ stock exhaust? Would like to pipe but enjoy quiet compared to my Suzuki.
LAB3
posted August 13, 2009 08:39 AM
The TRE is a cure for the popping you WILL hear if you install a full exhaust system,
With stock mufflers you will not hear the popping when you let off the throttle and let
the engine slow down the bike, I liked my 14 quiet too.until a 14 with a Yosh spanked me
0.22410702705383 seconds processing time
