BIKELAND > FORUMS > ZX-14.com > Thread: noise reduction plug NEW TOPIC NEW POLL POST REPLY
bluechris
hungry fool
posted August 13, 2009 02:32 AM
Has anyone used the noise reduction plug on any of brocks pipes. love the look of smeg but need to be less noisey in the early morning. Thanks for replys.
ride safe
  Ignore this member    Click here to visit bluechris's homepage.
smokehouse4444
XX to ZX
posted August 13, 2009 04:34 AM
I have one. At first it doesn't seem to make much difference, but once it settles into a regular idle, you can certainly tell. The Biggest difference to me is during any longer rides. That smeg just starts working my eardrums. With the NRP in, the exhaust note is a lot less traumatic to the ears, and kind of sounds like a P51 Mustang strafing by. Be careful, however, they fall out fairly easily. I've lost two already. I now keep the appropriate hex wrench in my pocket and check it almost everytime before I leave.
2008 Atomic Silver ZX-14, Brock's this and that, some other stuff, 260 in full gear, powered by Cheese
2005 Ducati 999 with all the goodies
Superman T
posted August 13, 2009 04:51 AM
+1, I've lost 1 already.... Make sure you keep a Hex wrench and torquue it frequent.... Worth the money if you don't keep losing it.
bluechris
hungry fool
posted August 13, 2009 05:30 AM
Thanks Guys. pretty expensive when they fall off. lol
ride safe
Zedexdragon
posted August 13, 2009 06:52 AM
I have the plug as well on my Smeg, HIGHLY recommend it!
Cheers
Kinley
icarus
posted August 13, 2009 02:00 PM
Guys, there is a revised version of the plug available from Brock's now. It clamps on the
outside of the baffle instead of using the set screws inside the baffle. I have one in my AH
and have had no problems with it. Plus it looks cooler too. Later...
8.820 @ 161.05
Bently
2012 14r In Blue and no Mods!
posted August 13, 2009 06:13 PM
Plug is the way to go helps alot
smokehouse4444
XX to ZX
posted August 14, 2009 04:49 AM
Well crap. Maybe I misunderstood, Icarus, but I could have sworn the last time mine fell off I talked to the Brock's guys and asked if there was a newer one that fit better and they said there was but it didn't work with the smeg. I'm trying to keep this one on for awhile unless I'm at the drag strip, but I may look into the newer one in the near future.
Learning2race
posted August 14, 2009 05:11 AM
I've got a new one that I've never installed if you want to make a deal - still in the original shrink wrap. Let me know if interested
icarus
posted August 14, 2009 02:36 PM
Smokey, is the plug you have black anodize? The new one I have is a plain aluminum
finish. I got mine early this summer. May try to call again on Monday to see if they have
any new info for you. Later...
8.820 @ 161.05
dcjens
Wet side of Washington
posted August 15, 2009 11:19 AM
keep it loud! wear earplugs. I got a reduction plug and took it back out after 2 days.
Black 06
Bluebyyou
Gettin My Curve On
posted August 15, 2009 03:33 PM
+1 any rider should be wearing earplugs anyway. The wind noise alone, especially higher speeds, will damage your hearing,
2007 Bad to the Bone ZX-14 flies out, full Muzzy exhaust system, PC III, BMC race
0.29422307014465 seconds processing time
