BIKELAND > FORUMS > ZX-14.com > Thread: Whenever you pull the pan NEW TOPIC NEW POLL POST REPLY
kawasakijockey
posted August 11, 2009 05:56 AM
Just because you dont see anything in the pickup screen doesnt mean there isnt stuff in there. Wash the thing out with a can of brake cleaner and blow it out with compressed air from the pump side of the tube. I was amazed what came out of mine. There was a lot of it. Mostly gasket material, clutch fiber, and a few factory machining shavings. Nothing hardly came out before using the brake cleaner so be sure to get you a can. When you do go to pull the pan and get a new gasket make sure to get new 670D2016 (2each) o-rings for the steel oil tube. Mine were in bad shape.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
posted August 11, 2009 05:57 AM
Very good advice. I also used Brake Kleen on mine, and inspected the o-rings closely.
kawasakijockey
posted August 11, 2009 06:10 AM
Something else too. When you put the pick-up tube back in the case it is easier to put the rubber seal in the case first and then push the tube in after. Trying to push it in with the seal on the tube can be hell.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
JR
drag racing
posted August 11, 2009 11:49 AM
dam i pulled my oil pan two time didnt look at the pick up to good. next time im gonna have to pull it sooner or later i used the same gasket it still leaks a little dont no from where might just buy a new pan. but good info will do next time
08 zx 14 lowered, straped in the
front, strecth 65, air shifter, pigs
windshiel, carbon fiber frame
sliders, full 2brother exhaust.
  Ignore this member    Click here to visit JR's homepage.
kawasakijockey
posted August 11, 2009 12:01 PM        Edited By: kawasakijockey on 11 Aug 2009 22:00
I had reused my gasket the first time I pulled the pan and it didnt leak until a month later. Got that one to stop leaking and one started on the other side of the pan a month after that. I have an oem gasket this time but next time its going to be a Cometic like my clutch cover has.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
JR
drag racing
posted August 11, 2009 01:02 PM
i touch the sides it feels dry but who knows where it leaking from lol. i guess i need a new gasket i hope or ill just buy a new pan
pazx14rider
posted August 11, 2009 03:28 PM
To add grease on all the o-rings is a good idea for reassembly to insure you dont tear an o-ring
jdrill04
posted August 12, 2009 05:58 PM
were did you order the o rings from? I need to check my pick-up, before I do I wont to order the orings and gasket.
kawasakijockey
posted August 12, 2009 06:17 PM
From the local dealer. If you dont have one close call Ron Ayers.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
0.23169207572937 seconds processing time
