BIKELAND > FORUMS > ZX-14.com > Thread: first time at the track NEW TOPIC NEW POLL POST REPLY
Newbusa
posted August 03, 2009 08:48 PM
First time at the track with the 14,Managed to get 12 runs over 2 days best was 6.59 at 114.6 ith a 1.71 sixty foot,Best speed for weekened was 116mph.That was with flys out,pc3 and Brock pipe on a 180 pilot power lowered and strapped.Not that great but was fighting 3 foot wheelies the whole weekened.I think my left hand needs some clutch practice,Traction was very good i ran 28psi in the rear.Any tips on clutch work?It seemed to be a bit easier to run with both feet on the ground as opposed to one foot on the gear side peg but harder to get it back to shift to 2nd.I think a airshifter would probably cut some crucial time there.
ninjaboy311
posted August 04, 2009 12:54 AM
Definitely get an air shifter. It is alot easier to launch with both feet on the ground. It gives you better balance, and improves your confidence of launching too. Get an extended swingarm or some extensions, and your 60 foot times will drop dramatically because you will be able to launch harder. Practice practice practice, be safe, and have fun!
posted August 04, 2009 05:40 AM        Edited By: eklipse636 on 4 Aug 2009 13:41
Extending it will fix the wheelie problem! You can get you some extensions for $200 and a new chain for $200 and you will be set! Its the best $400 I've put into my bike
0.24655985832214 seconds processing time
