BIKELAND > FORUMS > ZX-14.com > Thread: flush mount drain plug NEW TOPIC NEW POLL POST REPLY
northernkaw
posted August 02, 2009 12:00 PM
I was in my transmission shop the other day and ran across a plug that will replace the oil drain plug and give you a lot more clearance then the factory one. its off a jag transmission and has a built in o ring.in the pics I machined .100 inch off the end to give me 3/8 of an inch more clearance. I ordered another one to verify the part number. if its the one I ordered they are $8.00 canadian. the plug ends up the same thickness as the washer on the factory plug.
TooHype
Go Hard or Go Home !!
posted August 02, 2009 02:31 PM
PIX ??
LAB3
posted August 02, 2009 02:57 PM
Shane has some that work with the OEM washer. They work Great as you can grind off the guard that is in front of the plug for more clearence.
northernkaw
posted August 02, 2009 04:04 PM
the plug installed is no thicker than the eom washer when machined.
posted August 02, 2009 05:53 PM
Does a allen wrench fit it, or do u still use a socket? Pics would be great!
northernkaw
posted August 03, 2009 06:50 AM
allen wrench works. I am trying to send pics but thats a mission here. it looks like a flat surface with a allen head hole in it. I should have the part number the middle of the week and will post it. you can get them from a jaguar dealer for about $6.
14nooby
posted August 03, 2009 12:35 PM
Eklipse, do you need one for your 08? If so email me I have an extra one. It is flat with an internal allen head. My email is caquino003 at cfl dot rr dot com.
posted August 03, 2009 04:15 PM
Thanks a million noob!
masszx14
A mind beside itself!
posted August 03, 2009 04:23 PM
I'll have to get a couple- not lowered but somehow got some scrape marks on the plug guard... speedbumps and maybe coming down heavily from wheelies.
Great find and thanks for sharing
universal@mind
northernkaw
posted August 04, 2009 05:18 PM
the part number is JLM 20214 at the jaguar dealer the price is $8.40 canadian so it should be about $6.00 US. what I like is the recessed oring.
0.52981686592102 seconds processing time
