BIKELAND > FORUMS > ZX-14.com > Thread: Never turbo without clutch mods./ NEW TOPIC NEW POLL POST REPLY
davej
posted July 30, 2009 07:31 PM
Your most likely tired of reading about the Muzzy turbo Stage 1. 23K and sweet, 32K total miles. Fried the clutch. Installed new springs fibers and metals. The Shinko hooks up, testing every component that follows. This is a daily rider and road bike. Hey! beat Cycle World times for a Stock ZX-14. Only by a few tenths. Best time is 9.82 @ 147 mph. Terrible slow. Stock clutch, ouch! Reaching 32K on the 14. The clutch and tail license plate light bulb are the only repair problems. Track temp 120 F, altitude corrected 9,000 ft.
Triumph guy
zxbob
posted July 30, 2009 08:48 PM
My stocker lived to 9psi ..... then came time for the lock up !
Bob
BobC
posted July 31, 2009 12:17 AM
I'd want a bit better than 9.82 if I'd paid the money for a turbo, or was it the conditions ?
My non-turbo 14 did 9.84 geared 17/40, standard wheelbase and foot-shifting. What would yours do at sea-level on a cooler day davej ?
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
FlatoutBu
posted July 31, 2009 05:52 AM
Track temp 120 F, altitude corrected 9,000 ft. !!!!!! ouch
06 Blue 14
9.008 at 153mph @ 195 suited
1badzx12r
posted July 31, 2009 06:21 AM        Edited By: 1badzx12r on 31 Jul 2009 14:22
last time i was at the track the track temp was off the scale 105 degrees in the shade .. 7500ft alt at 750 feet .. 8pm at nite
davej
posted July 31, 2009 06:51 AM
The turbo has to try and suck hot air then compress it. GIGO, when the track is cool then wheel spin which can be mistaken for clutch spin or both happen. Turbos work well with an intercooler which I don't have. Bone stock Busas and 14's barely make it into the tens on this track..Many times have seen good riders think their going to kick butt then look in disbelief at their time slip. It's hot, it's high add the Sportsman class without diapers can make it hairy when you hit their oil. Going to the track today with a new clutch and comp springs. Feels like solid hook up now without the engine revving up smacking the limiter when it shouldn't happen.
Triumph guy
davej
posted July 31, 2009 08:46 PM
Novice moment, new clutch, Muzzy springs, hit the rev limiter in 1-3rd, 9.62 @ 146.6. Altitude 7,000 ft corrected, weight 543 lbs. Gross weight 720 lbs. Was a cool 91 F degree day.
Triumph guy
posted August 01, 2009 11:19 AM
Intercoolers aren't very effective for the 1/4 mile anyway, unless you have an ice box.
Intercoolers are more suited for distance to reduce heat soak for prolonged boost.
This is what Corky Bell writes in his turbo book anyway.
Nitrous is a great instantaneous intercooler though! LOL
almost_les
posted August 03, 2009 06:59 PM
dude, you make it sound like its impossible to run fast at that track. its really not that hard.
davej
posted August 04, 2009 05:52 PM
A 9.62@146.6 is crap, 1/8 sucks. Rider is heavy, compared to you, with little experience. What do you call fast for a daily rider? This is not a drag bike or it would be 143 lbs lighter with a slick and sporting 400 more hp..
Triumph guy
almost_les
posted August 05, 2009 10:19 AM        Edited By: almost_les on 5 Aug 2009 18:22
in terms of the average daily rider in utah being all motor and on a stock swingarm: high nines.
0.25397610664368 seconds processing time
