bigwillie3236
posted July 30, 2009 12:47 PM
Schnitz racing shift light
What is the easiest way to install Schnitz shift light without a hub.I was told that i could tap into wires to make it work.I have a pc3 but no hub.THANKS IN ADVANCE
Douglas Home
posted July 30, 2009 02:59 PM
Will do you mean a programable shift light , or just a LED light ?
I heard that with just a LED you pull the dash apart and tap into the shift light then use a relay to power a more powerful light ! Because of the CAN single wire system.
If you go the other way , I have a Raptor shift / launch blue LED's that I like,let me know and I'll post up wiring details.
Goodluck
Doug Mackay Australia
bigwillie3236
posted July 31, 2009 09:39 AM
Its the schnitz led.With just schnitz led would i need a relay? THANKS
Douglas Home
posted July 31, 2009 10:57 AM
If you are tapping into the dash led , I've heard that you do.Because it draws more power than the OEM desh LED.
If you can afford it ,instead of tampering with the dash seal, I would purchase a shift/launch light. Raptor and MSD are good.I love my Raptor ,bright as even in daylight!
bigwil
06 zx 14 turbo stage 3
posted July 31, 2009 07:01 PM
you cant tap into the powercomander ill check my bk tomorow i run my shifter thru it
your powercomander has shift time, shift kill built right in
luv the schnitz light its bright
thr hub has its plus plug and play but not needed
bigwil// going fast aint easy so turbo it
bigwil
posted July 31, 2009 07:07 PM
i would only run a shift/launch lite only if you were using a diffrent managment then the dynojet for the $$$ you can do mutch more with a hub
bigwillie3236
posted July 31, 2009 08:25 PM
I'm stuck with the pc3.Two more question before i tackle it. What size relay and would i need to disconnect the stock light?THANKS GUYS.
Douglas Home
posted August 01, 2009 07:23 AM
Haven't done it myself , but if you check what secification the stock dash shift light is in the manual ,get a relay that has a coil that matches that feed.
Goodluck!!!
