BIKELAND > FORUMS > ZX-14.com > Thread: GT30 turbo compressor o-ring NEW TOPIC NEW POLL POST REPLY
JDC
posted July 29, 2009 02:09 PM
I have the turbo housings, exhaust header and pi0pe ready to be sent out for ceramic coating.
While I was removing the compressor side houseing, inside there is an approx 5=6", thin orange o-ring. When ever the turbo was put together, about 1" had been dislocated and pinched/deformed, so the o-ring now is very loose and deformed.
I called Limited Engineering for a replacement, and they said:
1. they are not available to be replaced (at all)
2. you don't even need that o-ring.
If you don't need it, why does Garett go the the trouble to put them in?
KawaBonzai
Leader of the Back.
posted July 29, 2009 02:45 PM        Edited By: KawaBonzai on 29 Jul 2009 22:46
If I'm not mistaken there is a repair kit sold for the GT30, 32, and 45's correct?
It includes two O-rings, bearings, nuts etc ...
Can't understand why it's not needed either.
2009 ZX-14 Candy Lime Green
JDC
posted July 29, 2009 03:15 PM
Kawa,
Yes, I believe you are correct, and that O-ring is in the rebuild kit!
MJ
posted July 30, 2009 01:17 PM
Thats why I hate taking apart good working parts, things just become more and more of a pain as you go. I hope everything goes back together and works fine for you Personally I would have just used a kick-ass high temp paint and left the turbo together
JDC
posted July 30, 2009 01:24 PM
LOL.
That seal will get cut up, spliced and go back in if I can't find a replacement.
And I am with you... I hate it when taking things apart and those occasions when they don't go back well.
posted July 31, 2009 05:44 AM
JDC, you could probably use HIGH temp RTV silicone, like the copper colored stuff.
Its just the compressor side, heat won't be an issue.
0.23484492301941 seconds processing time
