BIKELAND > FORUMS > ZX-14.com > Thread: Steering Head Bolt question NEW TOPIC NEW POLL POST REPLY
epd345
posted July 28, 2009 02:04 PM
Just got my GPR and of course I dont have a socket or wrench big enough to fit the ZX-14 steering head bolt. Anyone know the exact size so I can make the socket purchase. Thanks
AcadianaZX
Advertiser
posted July 28, 2009 03:24 PM
36mm steering head nut. I have the GPR4 on mine. Like it a lot.
James
WindSwordNinja
posted July 28, 2009 04:36 PM
The steering nut is actually 35mm if I remember correctly however I couldn't find that size socket so I used a 36mm and just hoped that I didn't strip it.
It worked fine without any problems, just be careful with it when you torque it back on to 58 ft-lb.
2014 ZX14 Black and Green
2008 ZX14 Black and Red SE
1986 ZX1000R Black
"Faster, faster! Faster would be better!" (Serenity)
AcadianaZX
Advertiser
posted July 28, 2009 04:46 PM
Glad you came in windsword. I was wrong. 35mm is it, but 36mm is all I had also.
epd345
posted July 28, 2009 05:24 PM
thanks again
derpie
Dont judge a book by its cover
posted July 29, 2009 04:57 PM
Being as thought the 14 is so heavy ,does the stabilizer really make that much of a difference. Or is it only when you really push the bike hard you feel the need for the extra tightness ???
AcadianaZX
Advertiser
posted July 30, 2009 05:23 AM
After using the GPR and riding the bike without it, I find it floppy. It was a very nice addition for confidence when the bike wheelies.
derpie
posted July 30, 2009 06:21 AM        Edited By: derpie on 30 Jul 2009 14:23
Just trying to justify the price over here so its mainly for when the front wheel comes up ???
AcadianaZX
Advertiser
posted July 30, 2009 07:03 AM
It's also what's used in Road racing. Excellent for me in turns. Yea, I had wheel chatter the first time the front came down, very scary because I was'nt used to the bike at that time. Tank slap would mess my day up. I even checked that everything was in spec on the steering head before purchasing the GPR4. I wonder how many off the pro's here would advise in using a steering damper? Anybody?
epd345
posted July 30, 2009 01:10 PM
Derpie I have had it installed a few days now. Really like how it feels. Much more solid. Biohazard Cycles $388 shipped for the V4. Not bad.
derpie
posted July 30, 2009 01:42 PM
Yeah that's way cheaper then I saw it for maybe I will take the plunge. But I've never noticed any shimmy or tank slap. Is that only for the guys who redline there precious 14 every gear who notice this phenomenon .
Douglas Home
posted July 30, 2009 02:50 PM
My opinion is , if you need one it could save a lot more than bike repair/replacement !!!
If you get one that uses different hardware for different bikes then it is a good investment that can then be used on your next bike also.
Cheap life insurance.
Doug Mackay Australia
derpie
posted July 30, 2009 08:45 PM
Sold then , is it something I can install myself or do I need to go to the stealership.
Bluebyyou
Gettin My Curve On
posted July 31, 2009 02:50 AM
I just don't get the whole steering damper thing on the 14. I guess it's just feel good preference type thing. The 14 is the most high speed and wheelie stable bike I've ever owned. Of the dozens of times mine's set back down after wheelies it has very rarely exhibited even the slightest hint of headshake. IMHO five to six bills could be much better spent on this bike.
2007 Bad to the Bone ZX-14 flies out, full Muzzy exhaust system, PC III, BMC race
derpie
posted July 31, 2009 04:10 AM
Hmmmmmn
epd345
posted July 31, 2009 05:23 AM
Derpie it takes 5 minutes to install, very easy. You just need a 35 or 36 mm thin wall socket and a hex wrench.
derpie
posted July 31, 2009 02:34 PM
Nice , 5 minute's for you 6 hours for me . lol
epd345
posted August 01, 2009 08:44 PM
No way derpie,I'm borderline mechaically tarded and I did it. Just remove the original head bolt with the 36mm socket. Then attach GPR mount base using the new supplied nut. Tighten with 36mm socket. Remove the front tank mount screw. Take the the thingy that the steering damper arm goes into and mount that to the front bolt hole of the tank mount.(THERES ONLY ONE WAY IT FITS) After everything is torqued now mount the GPR on top of the mount with two 5mm hex head bolts and ur done.
posted August 02, 2009 03:35 AM
As for it being "the most stable bike it size" I've whelied mine and quite a few times I've had a good bit of head shake, one time ALMOST threw me off. I think if you ride a bike that will lift the front tire, its worth it.
that gpr you don't have to tap the 2 bolts into the frame?
Douglas Home
posted August 02, 2009 04:46 AM
Steering dampeners , if you don't like gravel rash , get one!
posted August 02, 2009 05:33 AM
The zx14 is the most stable bike I have ever owned.
That said a steering damper is a part you may never get to appreciate, as it can save your life and your bike when you do REALLY need it.
Its one of those items you will only REALLY appreciate when you didn't have one, and its too late.
derpie
posted August 02, 2009 06:37 AM
thanks for the info
0.2278790473938 seconds processing time
