BIKELAND > FORUMS > ZX-14.com > Thread: slowly getting there NEW TOPIC NEW POLL POST REPLY
Quarter Pounder
with Cheese
posted July 25, 2009 08:26 AM
Been getting better every time I hit the strip...last night I was getting used to the air shifter and 1 tooth smaller rear. I didn't like the rear sprocket, my 60' times were slower than what I was getting with the 41 tooth rear. I am usually low 1.6s and still looking to break into the 1.5s. It'll come, just more seat time on this bike. I've only had this bike about a month. Going again tonight with the 41 rear...should see a little more improvement.
Here's the runs in order:
60'......330'......1/8th............1/4
1.71 / 4.32 / 6.40@118.48 / 9.71@147.44
1.65 / 4.19 / 6.22@121.19 / 9.48@148.92
1.69 / 4.24 / 6.27@120.62 / 9.55@148.62
1.67 / 4.26 / 6.31@119.81 / 9.60@148.23
1.86 / 4.50 / 6.55@120.06 / 9.84@148.40 Spun out of the hole
1.65 / 4.18 / 6.22@120.09 / 9.51@147.5
1.68 / 4.19 / 6.22@121.30 / 9.49@148.10
1.66 / 4.18 / 6.20@121.45 / 9.47@148.18
1.70 / 4.30 / 6.33@120.85 / 9.61@148.48 Spun out of the hole
1.68 / 4.24 / 6.28@119.89 / 9.57@147.96
1.66 / 4.19 / 6.23@120.25 / 9.51@148.31
1.68 / 4.24 / 6.34@112.81 / 9.76@142.04 Foot shifted 1-2 then hit the limiter while thinking to myself (what the hell are you footshifitng for? ). Put it on the trailer after that run...
__________________
SWB 2008 ZX-14
9.19 @ 151
5.98 @ 123
1.53 60'
posted July 25, 2009 12:52 PM
12 runs in one night ... cool ... Leave the 40 tooth and pull the fys ...
Quarter Pounder
with Cheese
posted July 26, 2009 12:02 PM
I thought the 08-09 didn't really need to remove them?
SWB 2008 ZX-14
9.19 @ 151
5.98 @ 123
1.53 60'
posted July 26, 2009 12:28 PM
Well the 08 09 is better than the 06 07 but you will still pick up low end and even bettter you get full controll over your throttle ..
Quarter Pounder
with Cheese
posted July 26, 2009 12:42 PM
I'll pull them once I get a new map and a way to install it. I have to source a cable, and PCIII software since the PO can't seem to remember what he did with it.
SWB 2008 ZX-14
9.19 @ 151
5.98 @ 123
1.53 60'
posted July 26, 2009 12:51 PM
Or you can just wait till you come down in Aug ...We can pull the flys and I have the map you need... Plus we can toss it on the dyno and get some numbers for you ..
Bently
2012 14r In Blue and no Mods!
posted July 26, 2009 01:08 PM
Shoot 12 runs is nothing in a nite, i can easily make 20 passes on a tnt night at my track. good times QP put your 41 back on and I bet you see 6.teens and low 40's
Quarter Pounder
with Cheese
posted July 26, 2009 01:45 PM        Edited By: Quarter Pounder on 26 Jul 2009 21:46
that sounds like a good idea. looking like sometime around 10-22 Aug right now.
Will be interesting to see the differences in running down there vs up here.
SWB 2008 ZX-14
9.19 @ 151
5.98 @ 123
1.53 60'
0.30092787742615 seconds processing time
