BIKELAND > FORUMS > ZX-14.com > Thread: Led shiftlight from Schnitzracing NEW TOPIC NEW POLL POST REPLY
bigwillie3236
posted July 22, 2009 05:40 AM
Has anyone tried the 30 dollar led shiftlight that Schnitz Racing?
bigwil
06 zx 14 turbo stage 3
posted July 22, 2009 02:24 PM
got it on my bike above the gauges i lk it
i also have the d b screen so it fits nice
i ran mine thru a dyno jet muti hub so i can set it from my powecamander
bigwil// going fast aint easy so turbo it
bigwil
posted July 22, 2009 02:26 PM
heres a pic
Photobucket
bigwillie3236
posted July 22, 2009 02:51 PM
Bigwil,i have a power commander on my 14.What kind of connectors will i need?
bigwil
posted July 22, 2009 03:49 PM
i use the the muti hub by dyno jet plugs right in
it comes with wires and has a switch for
using 2 maps if you use spray i use mine 1 for street map and 1 for track map
with anti lag for my turbo it also has two diffrent
rpm activated leads you can use one or spray at a stet rpm
or for a auto shift if you whant, i also run my shifter thru my powercamander
so i can set my shift time/ kill time i leave my pc cord hooked up out the side so i can check
evrything
mayby to mutch imfo but can justifi getting the multi hub
aso there is a way to tap into one of the wires on the powercamander
ill check witch wire
bigwillie3236
posted July 23, 2009 02:32 AM
Thanks Bigwil for the info .
0.21518516540527 seconds processing time
