BIKELAND > FORUMS > ZX-14.com > Thread: New Transmission Shift Pattern NEW TOPIC NEW POLL POST REPLY
Ninja ZX-14
posted July 20, 2009 01:12 PM
Curious to know if there is a way to change the gear shift pattern from (1 N 2 3 4 5 6) to (N 1 2 3 4 5 6), where the neutral is at the very bottom of the gear pattern instead of between 1st and 2nd?
Ninja 14
posted July 20, 2009 01:17 PM
This is rich.
Lucky14
posted July 20, 2009 02:19 PM        Edited By: Lucky14 on 20 Jul 2009 22:20
I hear that it's really easy to change on the Busa ..................
gilberjj
Friend of Fast
posted July 20, 2009 02:43 PM
Why would you want that? I don't think it can be done, but even if it could, why would you want to?
Ninja ZX-14
posted July 20, 2009 03:22 PM
1 of the reasons is with the Neutral in between 1st and 2nd gear has caused many people to miss 2nd gear because of the space and it causes and there's a far greater chance of bending the 2nd gear shift fork, which many, many people have done. Once that's done you're talking about major labor, engine removal, major cost, etc. I'd personally rather have my neutral on the very bottom.
Ninja 14
posted July 20, 2009 03:42 PM
run it like a 5 speed then.
My Vmax is geared too low, and I don't even use 1st half the time
Your talking BIGGGG $$$
posted July 20, 2009 03:55 PM
I have never heard anyone missing the one two shift on a zx14 ... I have seen and heard in happen on Busas ,
GHOSTMAN
posted July 20, 2009 04:05 PM
I have, but that was because I was too lazy to move my damn foot. . .
I'm There Whether You See Me Or Not.
Ninja ZX-14
posted July 20, 2009 04:08 PM
Yeah, I'm going to have to ask my builder and a few others buiders to get different opinions on this mod and if it can be done and done at a reasonable cost. I would love to have it done while the cases are open. Wanted to see if anyone here knew or have heard of it being done, so I would know which direction to go.
Ninja 14
SteddyTeddy
posted July 20, 2009 04:48 PM
Do you even know what's involved to do this?? You would have to have a new shift drum made. It can be done but not cheap.
1badzx12r
posted July 20, 2009 05:41 PM
wait until he slams it into neutral with his new gear arrangement .. then he'll figure out why neautral is inbetween gears .. LMAO
Ninja ZX-14
posted July 20, 2009 06:20 PM
OK, thats the kinds of things Im trying to hear. No I don't know whats involved but once I find out whats all involved then I will make my decision. If it's doable and at a reasonable expense, I might wud consider it. If it's not worth the expense, then I'll do what I've been doing since "84", they usual gear pattern. No Biggie. Thanks for that advice Sheddy.
Ninja 14
Ninja ZX-14
posted July 20, 2009 06:22 PM
Slammin it into neutral wont tear nuthin up but slamming it into gear will, so this won't be a problem at all because if all else fails, the 14 does come with a gear indicator.
Ninja 14
dcjens
Wet side of Washington
posted July 20, 2009 08:41 PM
Didn't the old kawi's like the triple 500 and maybe the 750 have it 5 up? I'd like neutral at the top and be able to stomp it down for upshift. A 2 sided shift lever with the shaft in the middle makes up or downshift a downward motion? (old Honda trail 90's did it)
Black 06
posted July 20, 2009 11:03 PM
reinventing the wheel,
and as Robert said, wait till you kick it past 1st into neutral when leaned way over in first, or you kick it down and it hits neutral, then you srape the cartilage of your nose off the clip ons! LOL
Have you ever had a bike die, or go to neutral and sudden power loss while leaned over ina corner?
lets just say its a super heavyweight battle to pick it back up and get it balanced straight before it ends up lowsiding
SteddyTeddy
posted July 21, 2009 04:01 AM
That would also be thrown off by changing the gear pattern which in turn would throw off mapping in each gear.
BobC
posted July 21, 2009 04:42 AM
I haven't heard of a 1st to 2nd shift problem on the 14 either, I guess riders with poor technique would mess it up whatever the bike or gear.
I did consider using a racing pattern though, 1 up and 5 down. Mainly because sometimes after shifting into 6th at around 170 the wind pressure on the top of my boot has made it really hard to get my foot fully up onto the rest and out of the airflow. That costs precious mph in a standing mile, having your left foot work like an air brake.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
posted July 21, 2009 04:51 AM        Edited By: Shane661 on 21 Jul 2009 12:54
Nevermind...
0.2347629070282 seconds processing time
