BIKELAND > FORUMS > ZX-14.com > Thread: cam chain tentioner replacement NEW TOPIC NEW POLL POST REPLY
wfo
posted July 19, 2009 05:55 PM
can you replace the tentioner without removing the valve cover?
1badzx12r
posted July 19, 2009 06:02 PM
yes. unless your talking about the guide
kawasakijockey
posted July 19, 2009 07:26 PM        Edited By: kawasakijockey on 20 Jul 2009 03:27
You dont have to if it is the manual type but according to the service manual you have to have the cover off to disengage the plunger on the factory one..
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
87gtNOS
posted July 20, 2009 04:31 PM
If you are installing a stock replacement, you should be able to install it only if your cylinder head has the inspection port on the side of the head.
My 07 didn't, but an 08 I saw did. Others on here with 07' say theirs has the inspection port.
If you want a stock replacement, I have a brand new CONCOURS unit to sell.
Also, make sure that for whatever one you do, you order BOTH the Oring and the GASKET. The OEM unit has no gasket, just the oring....the APE unit uses an Oring and I put on the gasket too!
01 ZX12R
LAB3
posted July 21, 2009 06:01 AM
Bill Eason does a mod to the ZX-12 CCT I have one on order from him. Will I have
to pull the valve cover??
87gtNOS
posted July 21, 2009 06:53 AM
LAB3, do you have the inspection port?
01 ZX12R
posted July 21, 2009 07:02 AM
My 06 has the inspection port.... how come some of the 07's don't?
thutch26
thutch26
posted July 21, 2009 07:21 AM
just take the ignition cover off and ever so slightly turn the motor over backwards with a wrench just enuf to put some slack on the tensioner side of the chain, then put the modified 12r tensioner per 12r manual. whola! ur done.. mine works perfect!!
87gtNOS
posted July 21, 2009 07:27 AM
Maybe I got the special high HP head?!!!!!!!!!
01 ZX12R
LAB3
posted July 21, 2009 07:33 AM
I have not looked yet. When I get time I will check it out. If no inspection hole then what??
As I am going with a new ZX-12 Bill is reworking.
87gtNOS
posted July 21, 2009 02:49 PM
LAB3, this method sounds like a good way to do it also.
Otherwise, you are left with no choice, but to remove the valve cover.
Maybe Bill Eason will have some tips for you.
01 ZX12R
billeason
posted July 21, 2009 03:06 PM
I use the thutch26 method. If your careful its all you need to do........................Bill
bill eason
LAB3
posted July 21, 2009 03:08 PM
Thanks. When I have time I will look at the CCT on my 2007. Used a APE manual on a FJ1200 and adjusted as the post above described. I am taking long trips this summer
and want a auto CCT adjuster that is Quiet when I start a cold engine.
1badzx12r
posted July 21, 2009 04:01 PM
i don't know his method .. but i never needed to pull a cover on a stocker either .. that wire lock don't take much to trigger ..
billeason
posted July 21, 2009 04:05 PM
I should have one out to you by Friday i hope Lab3 ! As Todd said they work great and you never have to touch it again. I have 6 of them that should be finished Thursday. .....................Bill
bill eason
LAB3
posted July 21, 2009 04:49 PM
Thanks Bill and I need a second one for a friends 2006 ZX-14. Email me when two
are ready.
Louis
madskillz
posted August 28, 2009 10:40 PM
I am have a knocking noise,in my bike just started happening im at about 7k on a 2008 zx14
Please tell me how to fix this problem
Bluebyyou
Gettin My Curve On
posted August 29, 2009 04:13 AM
How about someone posting a helpful pictorial step by step how to on this mod??
2007 Bad to the Bone ZX-14 flies out, full Muzzy exhaust system, PC III, BMC race
LAB3
posted August 29, 2009 04:25 AM
Bill
Any word from the Machine Shop??????????
Louis
0.26588797569275 seconds processing time
