BIKELAND > FORUMS > ZX-14.com > Thread: Best Steering Stabilizer NEW TOPIC NEW POLL POST REPLY
epd345
posted July 17, 2009 11:20 AM
About to buy a steering stabilizer for the 14. Was going to go with the GPR because I have helibar risers. Any thoughts or problems. I heard the GPR's leaked? Also considering hyper-pro. Thanks
Wheelie
Old Man
posted July 17, 2009 11:36 AM
ohlins
wee
posted July 17, 2009 12:15 PM
I had a gpr and the only downside I found was I couldn't run a lowering strap on the front. It was really compact and out of the way of everything else
Shogun
posted July 17, 2009 12:46 PM
I have the GPR and have used it with and without Heli Bars.
It did leak after just a couple of months use. GPR fixed it and returned it quickly under warranty. No problems since (about 3k miles).
06 ZX14 - Arata exhaust, PC III, McIntosh Ext swingarm, Vortex lowering links, Racetech rear shock, Marc wheels, To be continued...
posted July 17, 2009 01:22 PM
I like the ohlins/scotts radial damper myself.
Adjustable sweep, and high and low damping adjusters.
WindSwordNinja
posted July 17, 2009 01:34 PM
I have the GPR and like it but I've never had to strap the bike to drag race.
It did weep a little when I got it a year ago but it's been fine for about 14K miles.
2014 ZX14 Black and Green
2008 ZX14 Black and Red SE
1986 ZX1000R Black
"Faster, faster! Faster would be better!" (Serenity)
epd345
posted July 17, 2009 04:59 PM
Thanks All, Wheelie/dubious, will the Ohlins/Scotts work with Heli Risers installed?
Wheelie
Old Man
posted July 17, 2009 05:05 PM
not sure about that.
wee
posted July 17, 2009 05:18 PM        Edited By: dubious on 18 Jul 2009 01:19
Yes it will work fine with the risers, as it mounts to the top clamp and the frame.
You have to drill 2 small holes in the frame for the bracket, so its not for everyone but it is a very simple procedure, and even supplied the tap and dril bit with my kit from HARD Racing.com.
I have had great luck with them in the past in motocross applications too, they can take allot of jostling, and mine have never leaked a drop.
Here is an old pic with the LSL risers I had.
702fowler
posted July 17, 2009 05:40 PM
i have the gpr and heli bars- clears no problem easy to use- knob color fades in the sun and does leak but gpr takes care of it-- both times
how do you spell relief ?
G U M B A L L !
masszx14
A mind beside itself!
posted July 17, 2009 07:41 PM
My GPR V4 has been on the 14 for over 1 year now with zero issues whatsoever.
I'm also sure that the Ohlins damper with the Brock's hardware can't be a bad choice.
universal@mind
epd345
posted July 18, 2009 11:02 AM
Thanks all
Rideharder
posted July 19, 2009 12:16 AM        Edited By: Rideharder on 19 Jul 2009 08:26
I run the Brock's strap with a gpr and have no problems..
GPR is the one I trust..
I've had it since 07 and no issues..
I also made a very easy mounting bracket for the GPR to allow you to use the LCD screen allowing you to have access to your key and your adjusting knob on your dampener..
  Ignore this member    Click here to visit Rideharder's homepage.
posted July 19, 2009 12:00 PM
what do you do with TWO LCDs?
Rideharder
posted July 19, 2009 02:11 PM
So I can data log my runs and adjust everything through a laptop..
epd345
posted July 21, 2009 12:29 PM
thanks for the assistance, went with the GPR V4
masszx14
posted July 21, 2009 01:16 PM
Nice!
Here's a pic of mine- I recently held in hand their older version and the
V4 is smaller and quite lighter
universal@mind
Niner9
posted July 22, 2009 09:41 AM
running the Scotts radial, last time out I noticed a splatter of oil around the damper. it's been on the bike for about 7k miles. not sure if I should send it in for rebuild???
Akro slip ons, Scotts Damper, Hel Brake & Clutch lines, Vortex Rearsets, Sato Frame Sliders, Power Commander, Custom Map, Flies Removed, BMC Race Filter, Marchenisi Rims, Corbin Seat, Ventura Pack Rack, Pazzo Levers, Zumo 550 GPS, Passport Radar Detector, Throttle Miester Cruise,
bad ass 14
posted December 04, 2009 08:03 AM
I wanna go wit the Ohlis,its a little more expensive then the others but I like. It looks sweet on the 10r as well.
Bad ass 14
Jason Gillum
posted December 04, 2009 09:25 AM
The aftermarket ohlins and the ZX10 stock ohlins are WAY different. Go with the Ohlins from Brock's, he has brackets to make it work with a strap AND heli bar risers. Just a thought
Brock's Performance...
posted December 04, 2009 09:26 AM
Ohlins FTW
87gtNOS
posted December 04, 2009 06:05 PM
Sorry, I don't want to go off topic.....but please explain why two?
I use one and data log, etc with it.
As for the stabilizer, I'd get the one I can afford! GPR likely!
01 ZX12R
slates
posted December 05, 2009 06:32 AM
I have a GPR V4 and it started leaking after 1.5 years. The did redo all the seals but it cost me to ship it back and forth. I like the size and looks of the GPR, but if I had to do it over I would have spent the extra money and gone with Brock's Ohlins.
posted December 05, 2009 10:35 AM
Ohlins is like Michelin, its only good for when having the very best matters most and money comes second
jarhead
posted December 05, 2009 10:54 AM
I have had my Ohlins for two years and no issues at all.
0.24412703514099 seconds processing time
