KawaBonzai
Leader of the Back.
posted July 13, 2009 08:59 PM
Crank breather to Pair Valves Mod?
I'm trying to visualize what somebody was telling me the other night.
The crank breather tube goes up to the airbox right?
It's job it to pump oil vapor to the airbox so it can be burned?
The pair valves are those things we buy block off plates for, the fresh air injection system?
Those two vlavles join into one tube and also go to the airbox?
So what I was told to do is put a "T" at the pair valves and run the crank breather to it.
there would be nothing going/coming to the airbox, so it can be sealed up.
philosophy is that by reducing crank pressure I'd gain 2+ HP?
Anyone perform this mod so far?
bruno nadeau
posted July 14, 2009 01:05 AM
(nothing going/coming to the airbox) so you have to plug the tube that come from the pair valve at the air box?
bruno nadeau
1badzx12r
posted July 14, 2009 04:10 AM
Edited By: 1badzx12r on 14 Jul 2009 12:11
well you can not do what your saying there .. cause the (pair valve) or kawi kleen air only flows fresh air at idle .. as far as doing this on a suzuki i don't know .. but i have dragracing freinds that take the crank case hose and tie it into the exhaust system to pull a vacum on the crankcase at high rpm .. does it gain hp who knows ..but they read it on the internet somewhere that it does ..
posted July 14, 2009 04:13 AM
Edited By: Shane661 on 14 Jul 2009 12:18
You remove the switching valve and replace it with a tee fitting. There are apparently some concerns with oil pressure and/or crankcase pressure fluctuation. There is plenty of info out there, research it more and draw your own conclusions.
davisag
posted July 14, 2009 02:04 PM
hi
yes have done it, and with two setups at the dyno, it has to be disconnected when mapping.
on both occasions we ran a final power run with it reconnected after mapping and power gain is between 2-3 hp at top end
i posted a picture of my set up around a year ago , you will just have to do a search
