BIKELAND > FORUMS > ZX-14.com > Thread: clutch ??? NEW TOPIC NEW POLL POST REPLY
06redzx14
posted July 13, 2009 05:23 AM
clutch ???
my clutch doesn't feel as if it is fully disengaging. I can pull the lever all the way to the grips and it still sounds like it is thumping into all gears when down shifting
should I bleed the clutch system?
LAB3
posted July 13, 2009 11:27 AM
How many times have you launched from a stop??? My guess is the clutch hub/basket has indentions in it from the drive tabs on the clutch plates. You Drag race you pay the cost.
06redzx14
posted July 13, 2009 11:39 AM
it's got a few hundred passes on it. the clutches have been in since August. I'll check it out today and see what I find
ninjaboy311
posted July 13, 2009 05:03 PM
Could have a partially warped steel. When you inspect them, if a steel has any resistance to coming out, it is warped. They should slide out nice and smooth and shouldn't get hung up.
06redzx14
posted July 13, 2009 05:21 PM
pulled the clutches out this afternoon all steels and fibers look great. my pressure plate does show some signs of the hd springs digging into the walls, but other than that everything looks good. When I pull the lever in the plates move freely, but the bike is still very difficult to role with it in gear and squeezing the clutch. I'll try and take it for a ride tomorrow
0.23183989524841 seconds processing time
