BIKELAND > FORUMS > ZX-14.com > Thread: More suspension questions NEW TOPIC NEW POLL POST REPLY
NeverKnow
posted July 13, 2009 04:14 AM
After turning 13k on the odometer of my 08 zx14, the bike no longer enters and exits a turn as one mass. The front and rear move independent of each other; the ride has become sloppy. I do not race so miles are all street. Will adjustments help at this point or are the suspension components at end of life?
kawasakijockey
posted July 13, 2009 06:03 AM
Like everything else, moving parts loosen up with wear. Spring preload will relax in time and cause too much sag. Start there. Readjust it and keep riding. You should check your steering head and swing arm bearing slack too. The most common problem with handling complaints is a very worn front tire or too low tire pressures. I dont think your supension is worn out though.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
NeverKnow
posted July 13, 2009 02:07 PM
Thank you for the feedback.
0.24061298370361 seconds processing time
