BIKELAND > FORUMS > ZX-14.com > Thread: How was the install on the muzzy air shifter?? NEW TOPIC NEW POLL POST REPLY
johnsonzx14
posted July 08, 2009 06:29 PM
Just curious guys.. Ive had one for awhile, just havent installed it yet... How easy was it...?
posted July 08, 2009 06:57 PM
not bad.
posted July 08, 2009 08:44 PM
not bad.
+1
johnsonzx14
posted July 09, 2009 07:04 PM
sweet, I might have to get that put on there this weekend.... Its used, but everything is there..
rtbain
old, fat and slow
posted July 10, 2009 02:30 AM
Good but a few points.
Wrap the braided steel air line in fuel hose. Braided steel line acts like a saw and will eat anything it rubs up against. I found 5/16” fuel line worked well. Split it with a box cutter; wrap it around the line then ty-rap in place.
I destroyed the horn/shift switch by adding “just a little more” torque. Not a fault of the design. Just in case it uses a double pole double throw center off switch. DPDT.
In general the electrical connections are very good. Make sure you have an o-ring pick on hand to ferret out the stock connections.
I charged my bottle with nitrogen. I know nitrous and CO2 will work. I prefer nitrogen because it’s inert. I keep a bottle in the garage for airing tires so it worked out great.
I function tested on a rear stand before hitting the road. Worked well for me.
Randy
  Ignore this member    Click here to visit rtbain's homepage.
johnsonzx14
posted July 10, 2009 05:42 AM
awesome, thanks for the input...
0.23401594161987 seconds processing time
