BIKELAND > FORUMS > ZX-14.com > Thread: Anybody using a PC5?????? Help. NEW TOPIC NEW POLL POST REPLY
johnbull
posted July 08, 2009 04:36 AM
As some of you may already know from other posts, my race car which uses a ZX14 engine caught fire last weekend and I need some help re. wires of the PC5 because I had to cut off the connectors since they were so melted together.
The PC5 is fine & I have a new ZX14 harness on the way. What I need to know is what colours from the PC5 go with which colours on the harness (the brown connectors on the harness) I would much appreciate it if someone could have a look at their PC5 plugged in and make a note of which colours go with what.
Any suggestions?
John Bul Racing. Malta.
johnbull
posted July 12, 2009 11:43 PM
All I need is some photos of the 2 connectors coming out of the PCV.
Can anyone help please????????
gilberjj
Friend of Fast
posted July 13, 2009 12:07 AM
dang...... wish I could. I have a pcIII. Good luck!
AcadianaZX
Advertiser
posted July 13, 2009 01:00 AM
John I get home from offshore in 3 more weeks. if you don't have any help by then I will take pic's for you then. Sorry about the fire. Send me your email address for a reminder. 3 weeks a long time to wait. Wish I could help know.
johnbull
posted July 13, 2009 08:46 AM
Cheers guys,
Thanks for your help. My email is johnbull@waldonet.net.mt
Heres a pic showing the damage and all the melted connectors. The PCV is virtually untouched as you can see under the side pod on the left of the pic. As I said, the only problem was that I had to cut the wires before the connector because they were so burnt.
JDC
posted July 13, 2009 03:38 PM
yikes....
sorry to see that damage....
Again, what exactly caused the fire?
WindSwordNinja
posted July 13, 2009 04:09 PM
John that is just tragic to see!
I'm glad you weren't hurt when it went up in smoke!
2014 ZX14 Black and Green
2008 ZX14 Black and Red SE
1986 ZX1000R Black
"Faster, faster! Faster would be better!" (Serenity)
johnbull
posted July 13, 2009 11:36 PM
The actuall cause of the fire was a problem with breathing. After about 4 laps going hard on the circuit, the engine began to chuck out oil from the crankcase breather (apparently this is quite a common problem and people have suggested that I remove the rubber breather pipe in the sump which is next to the oil pick up)
Once there was enough oil out around the engine it caught fire off the exhaust.
You can see it on this Italian TV program:
www.controsterzomotori.it & go down to video number 9.
The new ZX 2009 engine should be here this week (found one from the US with 734 miles on it)
Im still praying for someone with a PCV to turn up here on this forum!!!!!!!
Cheers,
Josh
johnbull
posted July 18, 2009 03:40 AM
Anybody managed to snap some shots of their PCV wireing connectors yet???
I would much appreciate anyones input on this.
AcadianaZX
Advertiser
posted July 18, 2009 11:18 PM
John, maybe just a shot in the dark here. Did you try calling Dyno Jet or the place you purchased the PCV? I have 10 more days and I will take pic's when I get home if you didn't have any luck.
gilberjj
Friend of Fast
posted July 18, 2009 11:23 PM
smokin has a pc5
AcadianaZX
Advertiser
posted July 19, 2009 12:39 AM
smokin has a pc5
Smokin, he might have the body work off to.
johnbull
posted July 20, 2009 06:32 AM
Yep I tried calling fuelmoto where I bought the PCV from and they said they dont have wireing diagrams and referred me to dyno jet. I contacted them through their web site but they havent given me a reply.
Thanks AcadianaZX, I look forward to receiving your pics.
johnbull
posted July 29, 2009 07:41 AM
AcadianaZX,
Can you please let me have your email address.
Cheers,
Josh.
AcadianaZX
Advertiser
posted July 29, 2009 09:34 AM
AcadianaZX,
Cheers,
Josh.
tjsynthetics@bellsouth.net
Any luck with the pcv? I have my body work off. I'll be trying to get it sorted out. I see a lot of black wires. Hopefully they have different color stripes so I can draw a diagram with pic's also.
James
johnbull
posted July 29, 2009 10:45 AM
No luck yet.
Fantastic, I'll send you an email tomorrow with some photos of what I've got. I should have the new engine and harness by tomorrow morning.
Cheers
Josh.
AcadianaZX
Advertiser
posted July 29, 2009 12:15 PM
Hey Josh, This is what I have. I'm not confident about the black wires. I'm not electrically inclined. I was hoping for the black wires to have strips on them. Hope this helps. I'll have the plugs ready for some more pics till tonight when I start getting the bike ready for the track. Let me know if I can catch different angles for you.
Shot of both male & female plugs from the PCV
Male plug top locking clip side, the black wire going into the white plug goes where the white wire w/ red stripe is in the male plug, that is my muzzy air shifter fuel kill.
Male Plug bottom
Female Plug top locking clip side
Female Plug Bottom
johnbull
posted July 30, 2009 07:34 AM
Thanks James,
Excellent! You're the man!! I'll let you know how it goes.
Cheers,
Josh
posted July 30, 2009 07:37 AM
My PCV wires colors are completely different...
johnbull
posted July 30, 2009 07:51 AM
I seem to have managed to match nearly all the colours against your photos.
So you are saying the black wire was originally where your W/red (flatshifter) wire is in the male plug correct?
If so, the only other wire I cannot see in your photos is the grey wire. Can you see a grey wire anywhere on your connectors??
Cheers,
Josh.
AcadianaZX
Advertiser
posted July 30, 2009 11:10 AM
Cheers,
Josh.
Hey Josh, Yes that's where the black wire in the white plug was.
No I don'have a gray wire in any of the connectors, just the black with a grey stripe in the female plug.
johnbull
posted August 19, 2009 09:40 AM
James,
Have just about finished wireing it up against the photos.
In the last pic (female plug bottom), right hand side one hole up, is that a black & a grey wire both going into one hole??
It looks like that on the pic. Can you pls confirm??
Cheers,
Josh
AcadianaZX
Advertiser
posted August 19, 2009 10:47 PM
James,
Cheers,
Josh
Hey Josh, Yes that's correct.
johnbull
posted August 20, 2009 12:17 AM
Thanks James, excellent.
And the black wire on its own is bolted to earth, correct?
Cheers,
Josh.
AcadianaZX
Advertiser
posted August 20, 2009 12:41 AM
Cheers,
Josh.
I think that's the one bolted under the water jug on my bike. I believe your correct.
0.22328495979309 seconds processing time
