karamjit242
posted July 05, 2009 02:19 PM
Edited By: karamjit242 on 5 Jul 2009 22:32
bike loses power
after ridding one mile from home bike started to act up - very smoothly just lost power there was no hickup or anything. i waited few mintues and started it - went well for few minutes and than turned off again.
after removing the left lower fairing there is some motor oil on it but the engine oil seems normal in the window.
recently cleaned by BMC filter and used ton of oil on it now that oil is leaking out of every hole possible.
mods: BMC race filter, PCIII, full exhaust system.
2007 zx14 pearl white
Quarter Pounder
with Cheese
posted July 05, 2009 02:37 PM
errr...so why did you use a ton of oil on the filter? You need to yank it out, clean it again and reoil it properly.
SWB 2008 ZX-14
9.19 @ 151
5.98 @ 123
1.53 60'
posted July 05, 2009 02:55 PM
Yes, if you over oil, it prevents air flow, and will choke off power, as well it will end up leaking out of the airbox drain, and will also make the engine smoke when the excess air fliter oil burns from getting sucked into the intake airstream.
karamjit242
posted July 05, 2009 03:09 PM
i will clean it up and see. however i did put 200 miles or so after reoiling the filter. i was thinking more about eroded ground on pc3
karamjit242
posted July 05, 2009 03:17 PM
instructions for filter service say apply oil Liberally. ...... i thought liberally meant soak the thing in oil. more the better.
posted July 05, 2009 05:25 PM
Its best not to oil the filter.....clean it let it dry and do not oil it...
TooHype
Go Hard or Go Home !!
posted July 05, 2009 09:16 PM
I only oil 1 side of the filter (the bottom) just enough to stain it.
cycle junkie
posted July 05, 2009 10:30 PM
quote: recently cleaned by BMC filter and used ton of oil on it now that oil is leaking out of every hole possible.
Sounds like you should run the stock air filter...
Your definitely not gaining anything with the bmc.
http://www.performancephotos.com
"Any society that would give up a little liberty to gain a little security will deserve neither and lose both."
-Benjamin Franklin
karamjit242
posted July 06, 2009 05:17 AM
do you guys also have oil staining on left lower fairing.
posted July 06, 2009 08:28 AM
Edited By: dubious on 6 Jul 2009 16:29
I was running the stock air filter with the backfire screen removed.
I have heard the K&N has better foam around the fliter, which would be my concern.
The better the sealing foam, the better the filter IMO.
If you ride in really dusty conditions, like around road construction:
After removing the entire airfilter assembly, and cleaning out my airbox for the turbo, I was not impressed witht he water / mud stains passing the airfilter seal .
The entire air filter assembly including the housing it slides into is a POS imo.
