BIKELAND > FORUMS > ZX-14.com > Thread: ZX-14 "No Decel Pop" map? NEW TOPIC NEW POLL POST REPLY
KawaBonzai
Leader of the Back.
posted July 02, 2009 11:23 AM
So, is there such a thing as a map for no decel popping?
Mod's ..
BMC race,
M14 header
M10 GP pipe
PC-III
Air Injection blocked off.
This is for friend who just got an 09 ZX-14 like mine. I don't mind the pop but he's trying to get rid of it.
I thought blocking off the air injection would cure most of the decel pop, but it's still there witht he blue flame at night etc ...
Can this be mapped out now? If you mapped it out can you send me a copy for compare?
KawaBonzai at Gmail dot Com
2009 ZX-14 Candy Lime Green
FastestBusaAround
I eat Fish...
posted July 02, 2009 11:40 AM
No, but if you're ready to lose your GPS indicator...there's a simple way. (NOT using a TRE)
FYYFF!!!
KawaBonzai
Leader of the Back.
posted July 02, 2009 12:02 PM
Do tell.
FastestBusaAround
I eat Fish...
posted July 02, 2009 04:02 PM
The green wire at the GPS harness, where you'd connect TRE. I believe shorting to ground through a 270 ohm resistor on that green, will cause the neutral map to engage, which stops the popping on decel. I have heard though that there maybe some downside to performance on the strip with that setup, but can't say 1st hand. Once you do that, the GPS indicator shows the bike in Neutral all the time. This is exactly what the TRE006a is supposed to do, for 80 bucks, whereas this setup costs about 3 cents and is the same exact deal...
FYYFF!!!
busaisbetter
posted July 02, 2009 06:10 PM
its normal to have and doesn't hurt your bike - so why go through the trouble.
well i have PC3 and dyno after putting pipes, BMC filter and still have the pop.
FIFTH
The Magnificent Bastard
posted July 03, 2009 09:15 AM
Kawa, email me at wfsportbikes@aol.com and I will give you an easy no muss, no fuss fix that will take 10 minutes if you have the right stuff on hand.....
BIKELAND > FORUMS > ZX-14.com > Thread: ZX-14 \"No Decel Pop\" map? NEW TOPIC NEW POLL POST REPLY
0.23480987548828 seconds processing time
